Protected Valve Stems
/ Protected Valve Stems #1
SpringHollow
Elite Member
South of Rochester, NY
Power Trac 1850, NH 2120
I have been planning on welding pipe or metal to keep my valve stems from ripping out. I have never had this problem but it has happened frequentoy to others. Before i put my expensive sealer in, i figured i had better do something.
Searching for metal valve stems, i found these recessed valve stems which might be a neat solution so I ordered them:
Amazon.com: Flush Mount Chrome Valve Stem System (Set of 4): Automotive
They are meant for fancy rims but might be a neat solution to the problem. I want to sandblast my rims but once i do, i will give them a try. Inflating the inner duals would be a pain but with the sealer, that should be a rare occurrence.
/ Protected Valve Stems #2
Just a word of caution if you decide to weld colars on the rims instead...
Welding on any rim with a tire mounted (even deflated with the bead broken) can have explosive results. Always completely dismount the tire first.
YouTube - Tire Explosion
http://www2.worksafebc.com/PDFs/investigations/IIR2005108320019.pdf
http://www.forestryforum.com/board/index.php?topic=42557.0;all
/ Protected Valve Stems #3
The last one I posted was actually the video I was looking for and has much more information than the earlier ones.
Thanks
Thanks for the warning! I am aware of the problem of welding on a rim with a tire attached. I have seen it mentioned here but I must admit it would have never occurred to me to even try doing it.
Ken
/ Protected Valve Stems #5
Ken
Good deal. I looking forward to hearing how those new stems work out.:thumbsup:
/ Protected Valve Stems #6
It looks like they have made them even shorter now.I have used steel stems on my truck for many years. I only had one failure, due to jerk at tire repair shop. They never rot or Blow-out of wheel. I might just order some for my Bota. Thx. Jy.
Hi JY,
These are not normal metal valve stems but recessed metal valve stems
I just test fit one on a beat up spare rim I have and it looks like they will work. I can not say they will not leak yet but there was enough clearance that the cap nor the nuts hit the rim.
After I actually ry them, I wll let you know how they do.
Ken
Now the big question is, can i remove the valve stems from these in order to add the tire sealer.
Ken
just checked to see - the internal valves in the stems look like they can be removed just like normal stems
/ Protected Valve Stems #9
Do you need a special air chuck to put air in the tire?
No, but you need to thread on an extension tube before you can add air. The extension has a piece of metal in it that presses down on the internal stem when you press down on the extensions internal stem with your air chuck.
I really am hoping that this works out because it is a nicer solution versus welding on pipe or plate protectors. Pure luck that i happened to see them and realized that they might work.
Ken
/ Protected Valve Stems #11
Ken
Just order a couple extra of those threaded extensions. If my luck with lost tire gauges is any indicator of what would happen to those tubes. ;)
/ Protected Valve Stems #12
It hasn't been long but I was wondering if you tried these and if you liked them
All I did was try them in a dented up rim. I will have to wait until snow season is over before i can afford to take the duals off.
Ken
/ Protected Valve Stems #14
Well it has been a while and I wondered if you habe tried these yet. It looks like a good solution. I ripped a valve stem off yesterday moving brush around so....
I have been using them for about 7-8 months now in 4 of my tires with no problems. Ia m glad I installed them. But these tires now have the bullet proof sealer in them so I have not had to add air. To add air, you have to screw in a supplied extension.
Ken
Just an update: I still have not had to add air to the tires because of the sealer. Before the sealer, I was adding air every week or so due to rim leaks etc. No issues with the valve stems but then I have not had to use them to add air.
Ken
TANK MANIFOLD (A58216)
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2005 MACK CV713 MIXER TRUCK (A63569)
2005 MACK CV713...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Attachments, implements, & more 2/26/26 6pm online only (A64047)
Attachments...
