Protected Valve Stems
/ Protected Valve Stems #11
No, but you need to thread on an extension tube before you can add air. The extension has a piece of metal in it that presses down on the internal stem when you press down on the extensions internal stem with your air chuck.
I really am hoping that this works out because it is a nicer solution versus welding on pipe or plate protectors. Pure luck that i happened to see them and realized that they might work.
Ken
Just order a couple extra of those threaded extensions. If my luck with lost tire gauges is any indicator of what would happen to those tubes. ;)
/ Protected Valve Stems #12
It hasn't been long but I was wondering if you tried these and if you liked them
All I did was try them in a dented up rim. I will have to wait until snow season is over before i can afford to take the duals off.
Ken
/ Protected Valve Stems #14
Well it has been a while and I wondered if you habe tried these yet. It looks like a good solution. I ripped a valve stem off yesterday moving brush around so....
I have been using them for about 7-8 months now in 4 of my tires with no problems. Ia m glad I installed them. But these tires now have the bullet proof sealer in them so I have not had to add air. To add air, you have to screw in a supplied extension.
Ken
Just an update: I still have not had to add air to the tires because of the sealer. Before the sealer, I was adding air every week or so due to rim leaks etc. No issues with the valve stems but then I have not had to use them to add air.
Ken
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2018 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A59230)
2018 Peterbilt 567...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
5004 (A55851)
5004 (A55851)
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
