3-Point Hitch Proper technique for tilling
/ Proper technique for tilling #1
generalbegg
Ulen, MN
Kioti CS2410
Hey all, I've got a complete newbie question about tilling. I got my new tiller hooked up to my cs2410 today for the first time. When tilling I used the 3 point hight adjustment to set the tiller down. Do I leave the hight adjustment knob down while tilling, or put it back in neutral? As I was tilling with it in the neutral position, I noticed that when I would go over bumps the tiller would be pushed up and then stay at that height so if I didn't catch it, I wouldn't be tilling as deep. I'm just not sure if is ok to leave it in the down position.
Thanks
/ Proper technique for tilling #2
I use the depth adjustment on the tiller for the depth control and put the 3pt all the down.
/ Proper technique for tilling #3
Put the 3 pt down as far as it will go and let it float. Use the skid shoes on the tiller to adjust height if you don't want it at full depth.
/ Proper technique for tilling #4
Depends on how your tiller operates, especially in virgin ground. I sometimes use the 3pt to hold the tiller up on first pass to reduce bounce, and let it just slice into the sod. Then progressive lower it as I make a second pass. If the ground is already tilled, I set the 3pt all the way down and go, using the tiller skids to adjust depth.
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
