3-Point Hitch Proper technique for tilling
/ Proper technique for tilling #1
generalbegg
Ulen, MN
Kioti CS2410
Hey all, I've got a complete newbie question about tilling. I got my new tiller hooked up to my cs2410 today for the first time. When tilling I used the 3 point hight adjustment to set the tiller down. Do I leave the hight adjustment knob down while tilling, or put it back in neutral? As I was tilling with it in the neutral position, I noticed that when I would go over bumps the tiller would be pushed up and then stay at that height so if I didn't catch it, I wouldn't be tilling as deep. I'm just not sure if is ok to leave it in the down position.
Thanks
/ Proper technique for tilling #2
I use the depth adjustment on the tiller for the depth control and put the 3pt all the down.
/ Proper technique for tilling #3
Put the 3 pt down as far as it will go and let it float. Use the skid shoes on the tiller to adjust height if you don't want it at full depth.
/ Proper technique for tilling #4
Depends on how your tiller operates, especially in virgin ground. I sometimes use the 3pt to hold the tiller up on first pass to reduce bounce, and let it just slice into the sod. Then progressive lower it as I make a second pass. If the ground is already tilled, I set the 3pt all the way down and go, using the tiller skids to adjust depth.
Lowe Quick Attach 1650 Classic Hydraulic Auger Drill & Bit (A66285)
Lowe Quick Attach...
2004 International School Bus (A64194)
2004 International...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
