proper RPM for auger?
/ proper RPM for auger? #1
cart99
Northern VA
Kubota B3030
My neighbors and I were doing some work that required running a post-hole-digger off a B7800. Two of us said that it was best to run the auger at the recommended rear PTO speed of 540 rpm, but the third felt that that was meant primarily for mowers and that the auger worked better and was probably safer running at a lower rpm.
Who was right? I will say which side of the debate I was on once I get some responses /forums/images/graemlins/smile.gif
/ proper RPM for auger? #2
I always start the auger slowly and build speed depending on the soil conditions. The PHD is probalby the most dangerous implement I can imagine and needs to be treated with some level of respect.
/ proper RPM for auger? #3
I never run my post hole digger at PTO speed, to hard to control.
I run my post hole digger just above idle and occassionally speed it up to clean the hole out.
/ proper RPM for auger? #4
I run mine at idle, maybe slightly higher. The only PTO implement I run that slow.
ksmmoto
/ proper RPM for auger? #5
I've never operated our PHDs anywhere near 540 PTO rpms during thousands of fence post installations.
It'd just be a dangerous way to waste fuel. /forums/images/graemlins/tongue.gif
/ proper RPM for auger? #6
I think you'll find an almost unanimous opinion that you at least start very slowly. I wouldn't want to be anywhere in the vicinity of one that started (or was pulled out of the hole) running at the 540 rpm PTO speed.
/ proper RPM for auger? #7
I also agree with Bird & the rest of the boys.
So, what side where u on? /forums/images/graemlins/grin.gif
/ proper RPM for auger? #8
With my deep sandy land, I never have to go above idle. On my former deep clay soil I would often speed up to clear the auger bit. I doubt I ever got to 540 rpm on the PTO.
Vernon
/ proper RPM for auger? #9
My Land Pride PHD instructions say to use a max of 320 pto rpm. I usually dig at just above idle.
/ proper RPM for auger? #10
If the ground is hard and or rocky, you will find that the auger doesn't have time to cut in if running to fast. In soft soil, if it is running very fast there is a larger chance that the auger will screw itself in and then you will have fun getting it out. Like has been said it is better to run it slow.
Wow that was unanimous. I was the lone dissenter, saying it would be better to run the auger slowly, but it wasn't my rig and I'm still a tractor newb, so I didn't force the issue. I'll know better next time.
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
2017 CATERPILLAR 950GC WHEEL LOADER (A64279)
2017 CATERPILLAR...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
2011 Ford F-250 RKI Service Truck (A61573)
2011 Ford F-250...
