Proper inflation?
/ Proper inflation? #11
Why the massive price? (other than the physical size of the tyre) Well, rough agricultural terrain requires a tractor tyre that is resistant to irregular wear, abrasion and puncture. A tyre for a tractor or agricultural vehicle must be considerably stronger than the average passenger tyre or commercial vehicle tyre. The reason for that is quite simple, considering the fact that tractors and agricultural vehicles often come in contact with rough on-road and off-road conditions.
The biggest problems with tractor and agricultural vehicle tyres are abrasions and irregular wear, considering the surface drivers of tractors and agricultural vehicles often find themselves on.
Tractor and agricultural vehicle tyres can be compared to passenger tyres and commercial vehicle tyres in one aspect – the properties they can deliver on certain surfaces. For example, if the driver of the tractor often deals with dry conditions, such as small pebbles or debris, there will be a need for a tyre that can handle these kinds of surface conditions.
Short version; they're 'speciality' tyres.
/ Proper inflation? #12
I run my front tires at max psi listed on tire, 45 psi (I do have a slow leak in one). I do a fair amount of heavy lifting and have broken the bead on that front tire a few times because of low tire pressure.
Ratchet strap in the middle of the tire, tighten and aired it up... has re-seated the bead.
Rear tires I check once in a blue moon, once it didn't even register but you couldn't tell by looking at it. Aired it back up to 20 psi.
/ Proper inflation? #13
Checked the sidewall...all it gave was a max of 30-odd psi. I drove it around today at 20+ psi and it's still a tad bouncy. I'll knock it down to 15 or so and see what it feels like.
I drop them as low as I can with these constraints: the tire stays on the wheel, if a drive tire it doesn't slip on the rim when under a heavy load, I watch the sidewall and load and if sidewall shows much pooching I air it till it's barely visible. Once finished with load, if seldom I bleed back down. If frequent I leave it be and get my seat air cushion, OTR truckers use them, on the www, $90 just a little air, maybe half psi, blow up by mouth with just enough air presssure to make them work....best $90 I ever spent.
/ Proper inflation? #14
I found this - http://www.titanstore.com/info/499505.
$777 dollars? Really? Holy cow...why the massive price?
I can't really say, but here are a couple ideas.
First and foremost, that is a really oddball size. I have never seen it before, although truth be told I'm not an experienced AG guy. And "if you need it you will pay for it".
Coupled with Reason No1, anything that is low production will be expensive. The simple fact that it costs a lot more to do low production runs on anything, and something like a tire where you have massive upfront costs for engineering and tooling, plus all the typical setup inventory issues and it all adds up to $$$$.
/ Proper inflation?
Hmmm....I'm getting the sense that they are indeed an oddball size. I will ask at the dealership if there are substitutes to be had in my situation. They're getting to know me quite well now....I bought bolt-on pallet forks last week, and they have 3-point quick-hitches on sale this month.
/ Proper inflation? #16
Not sure how to enter in the metric equivalent of 13.5 x 16.1 - which Are the only numbers on the sidewall.
First number is tire width, and second is the diameter of the mounting flange upon which the tire is mounted.... like measure the tire bead diameter (the hole in the doughnut width) with the tire off the wheel
MM to Inch conversion is 25.4 mm per inch. So 13.5 x 16.1 = 343 mm x 409 mm.
IF you have a 3rd dimension it's overall diameter when inflated. My R4s only have the 2 but my R3 (turfs) add the overall dia as I posted in my earlier reply.
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
John Deere 24in Digging Tooth Bucket Excavator Attachment (A60352)
John Deere 24in...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
Madvac CS500 Sweeper (A61166)
Madvac CS500...
43018CFL (A59228)
43018CFL (A59228)
60" HYD BRUSH CUTTER (A52706)
60" HYD BRUSH...
