Price Check Propeller shaft cover
/ Propeller shaft cover
winston1 said:
I wouldn't worry about the holes. The main purpose of that cover is to keep stuff from wrapping around the shaft and safety. You could probably weld the holes up in place but if you ever take it off that would be the ideal time to do so. You could patch with a little rubber and a couple of hose clamps.
I had the same thoughts. Thanks.
/ Propeller shaft cover #12
I believe that is just a straight piece of thin wall tubing--I would just take it off and make a new one. If you took it to a muffler shop they could probably whip one out in a couple of minutes. I would also paint it Yanmar RED!! :laughing:
While its main purpose is to keep things from winding up on the shaft, the holes will enhance collecting and retaining things that should not be in there, water, dirt, oil, and debris, therefore, I would replace it, or fix it.
Mike
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A59823)
2017 KALMAR OTTAWA...
2013 FORD F250 (A60460)
2013 FORD F250...
2019 FORD F-250XL EXTENDED CAB UTILITY TRUCK (A59823)
2019 FORD F-250XL...
