Progress!
/ Progress! #101
The turkey issue has a lot of layers to it. There are no turkeys where I live, and there hasn't been any for decades. The demise of wild turkeys is blamed on farming, chemicals and fire ants. The state has been working on ways to reintroduce turkeys to East Texas for a very long time with total failure. About ten years ago, the tried a new method of mass release of birds in an area of ten square miles or more. First they find an area with habitat that they feel will support turkeys. Then they get all the landowners in that area to agree to allow them to monitor and track the turkeys on their land. Basically allowing them onto their land whenever they want to observe them. Once they block in that 6,400 acres or more, then they will release a hundred birds at a time, over several years. Predators take out quite a few of them right away. Then fire ants are blamed for killing chicks when they first hatch. Those that survive are increasing in numbers, but there is a huge drop from the initial release.
Once an area that has been cleared is left alone, it becomes overgrown with trees right on top of each other. Inches apart, and so thick that it is impossible to get through them. Slowly, as they grow, some of those areas will open up a little, but still too thick for an understory to develop. It is not uncommon to have thousands of trees growing on a single acre. I don't know what the ideal number of trees per acre is for wildlife, or what it was hundreds of years ago, but I'm guessing it should be in the dozens of trees per acre instead of thousands.
Wild Hogs do best in super thick woods. Deer struggle and tend to be at the edge of it, where possible. Deer numbers here vary from one per 40 acres in the thicker areas, to four times that many in more open areas, or even more. On my land, I'm creating open pastures of several acres, with wooded areas that open between the bigger trees with small pockets of thick areas. Since doing this, my deer numbers have increased dramatically. I have two pet turkeys and I've thought about getting more and letting them free roam over my place once I get it fenced. I would love to see flocks of turkeys, and in all reality, the only way it's going to happen is if I make it happen.
Yeah, they are completely "reintroduced" here. Not shy about coming up to the house when wife feeds the birds. 😁
/ Progress! #102
Did you build that fence? The older I get, the more I admire a really nice fence!!!
/ Progress! #103
@Torvy Can you tell us what is going on here? I am late to this thread and do not want to read it all.
So you are developing land? Where? How much?
Looks great so far!
/ Progress!
Looks great so far!
We bought our ~20 acres of heaven here in NE Texas about 2 years ago...its been our retirement plan for 20+ years. Unfortunately, it coincided with the virus... The framing is the shop, 40x30x16. They will start on the house tomorrow (foreground). It is 40x50, with a single slope roof. The view is from the tree line looking toward our back porch.
It is mostly Loblolly Pine. We just got back to FtW from there about an hour ago. It is 2.5 hours from here in the city. I should already be retired, but delays are going to make me work until May or so.
/ Progress!
Pictures from Monday. As of today, the garage/shop is done except for garage doors and electrical. They had two crews working, one on each structure.
/ Progress! #108
I like your color choices for your shop. How tall are the walls?
/ Progress! #110
A Texas State Biologist told me that if you went back in time a couple hundred years, East Texas would look completely different. A lot less trees, more space between the trees, and less brush. This is the main reason turkeys don't do well here.
When people moved here, they cleared the land, farmed it, then abandoned the farms and let the land grow back up. From your pictures, your land looks like mine. Super thick. It will take a thousand years for Mother Nature to get it back to where it is supposed to be. Wildfires will clear the understory, the big trees with choke out the small trees, and the native grass will cut down on the weeds.
Ideally, you want to remove 75% to 90% of all the trees on your land if you want it to be "natural"
You're exactly right. I've recently seen pictures from early 1920's of a forest in E. Texas where the trees were very large but were not close together and there was almost zero undergrowth. Beautiful!
/ Progress!
Just got back from hauling some materials and random things to store at the new place. The plumbers were there wrapping up the rough-in. We have water! No fixtures yet, but everything is stubbed in and the hose bib works. Got to watch them use the mini-ex to refill the trench. They were very nice and also back filled a big hole in the driveway that had been formed by all of the heavy equipment. 100% not the plumber's job.
We should get wiring and drywall in the next week or two. The duct work is already in place for the A/C. Siding is all on. There are a few things they need to correct, but nothing critical.
/ Progress! #112
You're be living there in no time!!!
In my experience, nobody makes a bigger mess then the sheetrock guys. They just through everything on the ground, then they cover it with as much joint compound as they can possibly drop, and then walk on it so they can spread it everywhere.
The only thing worse then the mess they make, is when one of them decides to be cute and he fills in an outlet box. You can't tell tell that there was ever a box there, but when you are connecting all your wiring, you'll have a line that only has power for so far, and then nothing.
/ Progress!
Even though we are going with stained concrete floors, they have already covered the whole floor to protect it as if there was hardwood down. The stain is not even added yet.
I'm a little weird. I actually enjoy hanging sheetrock. Part of the shop/garage will be enclosed and eventually living space (for kids/guests). I am doing most of that myself. Next on my agenda is to buy the trailer. It costs about $100 in gas to drive the truck back and forth. The trailer should reduce the number of trips. Plus, it will be big enough to take full sheets of drywall. Also, I have to wait for the electrician to run the wire and such for the garage before I can insulate and enclose that part.
Met with the realtor here (a family friend) and will probably list current place around March 1 (if I get my way). If it sells/closes quickly, I can live in my garage by then....I think. Worst case, we should be out there by June.
/ Progress! #116
The house and shop look really nice. The older I get, the more I appreciate having less things to take care of. You shouldn't have to do anything to those buildings to keep them looking nice!!!!
/ Progress!
That's the plan. We are not 'fancy' people. We don't entertain, other than ourselves and our kids. I wanted the roof slopes on the house to be easy to access. I don't like heights. The 'lawn' will be as low maintenance as possible. Unlike many here, I don't find joy in keeping a lawn. Oddly enough, I rather enjoy other aspects of property maintenance.
/ Progress!
Good to know, Eddie. My part of East Texas is only about 40 miles NNE of your part, if I recall correctly. I haven't seen a snake out there, but I'm sure they are there. As long as they eat vermin and keep their fangs to themselves otherwise, I am all for snakes. What varieties do you see most often?
In other news, crew was out today installing the septic system. Unfortunately, they parked a truck right in front of the camera that had the best view of that spot. The tank itself is going in the space to the left of the house (as viewed in the photo above). It will service both house and 'barn'.
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A59910)
2014 FREIGHTLINER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
John Deere 8310R Tractor (A64047)
John Deere 8310R...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
2006 Montone AD24465448 End Dump Trailer (A61573)
2006 Montone...
