Professional electrical crimper
/ Professional electrical crimper #1
MarkLeininger
Platinum Member
Chicago suburban
Kubota 2710
I want to buy a professional style crimper for electrical connectors for splicing wires on cars, tractors, etc. I've seen crimpers that are ratcheting and squeeze the connector uniformly so that it gets a good connection and doesn't destroy the insulation. Anyone recommend a brand, hopefully one that doesn't require special connectors so I can use what is commonly available. I've found one that comes with a set of interchangeable jaws and it looks like a good quality unit, but it only takes connectors purchased from that manufacturer.
thanks
/ Professional electrical crimper #2
I have used all kinds of connector and didn't really like any of them. That is until I started using Posi-Lock connectors. The last several months, I have been using them and they are great.
/ Professional electrical crimper #3
I work as an electrician on boats make hundreds of crimps a week so I feel I have some experience on this subject.
As far as crimpers...it does boil to preference but there are a couple that are the most popular in our boat yard. I own about a dozen different crimpers and they are all good, name brand models...but they are not all equal. I have a ratcheting model which is good but requires care in use and you need to make sure to put the terminal in the right way or you won't get a good crimp. They are really made to be used with "double crimp" terminals which crimp on the wire and then make a second crimp on the insulation for double security. But they can be used with regular single crimp connectors. My favorite crimper is this Snap-On crimper which also happens to be the favorite of a couple of other electricians I know. It makes good crimps, is easy to handle and has long handles so your hands don't hurt at the end of the day.
As far as terminals, the best I've used are the kind that have built in heat shrink such as these. They seal out any moisture and prevent corrosion of the wire. But you need to carry a heat gun around for the heat shrink.
Hope this helps.
/ Professional electrical crimper #4
I HATE doing auto/truck/trailer/tractor electrical work. Let's make that abundantly clear from the beginning. When I HAVE to do any, I want E.A.S.Y. That means having the right tool for the job in most cases.
Klien model #1005, 9-3/4" crimper. for insulated and non-insulated crimp-on connectors. Handles connectors for 10 to 22 AWG wire. Also has wire cutter built into nose of crimper. Very thin, and long handles permit crimping where your hands aren't blocking your view.
I had 3 other crimpers in my box prior to finding these Kliens. They all three went into the "these are for people to borrow" box. No need for another crimper any more.
/ Professional electrical crimper #5
That looks just like the Snap- on mentioned in the previous post, but at 1/3 the price!
/ Professional electrical crimper #6
</font><font color="blue" class="small">( That looks just like the Snap- on mentioned in the previous post, but at 1/3 the price! )</font>
It looks like it but it's very different. I have the two different Kleins including the 1005 and the Snap-on IMO is better because it has more leverage and can crimp up to #6 crimps with no problem. Try that with the Kleins and your hands will be killing you after a couple. That's because the Kleins are shorter and lighter. Each has its purpose but I still feel that Snap-on is the best "all-around" crimper.
Thanks for all the replies. I've got a little research to do.
/ Professional electrical crimper #8
My background is in aviation electrical.
I would suggest that you check AMP as they have a very wide assortement of wire conector tools.
In fact many crimping tools out there are copies of AMP.
They specialize in crimp connectors and tools and are aerospace approuved.
There go/no go ratchet crimpers are simply the best.
You will find them listed in yellow pages in most major cities.
/ Professional electrical crimper #10
I will second what PILOON said the AMP crimpers are the best built and are FAA approved for aricraft wiring.
They are also the most expensive.
/ Professional electrical crimper #11
I have not ever used AMP but have a few Paladin crimpers. My favorite while not for electrical is the one for RG6 coaxial cable. PALADIN
/ Professional electrical crimper #12
Try these. tool aid
Not super expensive, work well with all of the 3M connectors and the heat shrinkable type. A butane or propane torch works on the shrink type too, but you gotta be more careful. Or sneak out the wife's hair dryer /forums/images/graemlins/wink.gif
JerryG:
Posi-lok wins my award for most ingenious thing I've seen in crimping technology. There is no end of smart inventions.
Shimon:
The snapon looks similar to the crimper I have, and one problem I have is damaging the insulation on the fitting. Am I just squeezing too hard, or is there something about the jaws on the snapon that prevent that from happening? I imagined that the ratcheting style crimpers would be like the crimpers for coax fittings: it doesn't matter how hard you squeeze, you can't destroy the fitting because there's a stop on the tool.
/ Professional electrical crimper #15
Here is a link to the ones I'm referring to, look down the L/H colum, they are AMP 59250 for the red and blue splices 16/18ga and the 59275 for the yellow and white 20/22ga.
There are four tension adjustments depending upon insulated or not insulated terminal.
/ Professional electrical crimper #16
I also find some crimps are just better then others. StaKon are about the best I have found. 3M use good quality material in the insulator.
/ Professional electrical crimper #17
I'll also recomend the AMP then the Snap-On crimpers recomended.. With that said, I would also like to add that a wire crimp is a quick, easy temporary repair.. Although widely accepted, most are not very good quality repairs..They can weaken the wire if over tightened and will(unless sealed) allow corosion and moisture to infiltrate the harness.. I may be a little picky in this area, but when I make a repair, I dont need to do it again(plain and simple).. The best repair would be solder and heatshrink(with glue).. With a good kit its just as easy as crimping...
BTW, even Ford Motor Company has addopted the AMP crimp tool that comes as part of a kit including the bare solderless connectors, crimping tool, and heatshrink(with glue).. This is a good crimp, but.........(I still prefer solder)
/ Professional electrical crimper #18
</font><font color="blue" class="small">( one problem I have is damaging the insulation on the fitting. Am I just squeezing too hard, or is there something about the jaws on the snapon that prevent that from happening? )</font>
It's usually due to poor quality insulation on the terminal. Most "automotive" style terminals use a hard plastic insulation which is more likely to crack or harden. These are usually dark blue (14-16ga) or dark yellow (10-12ga). The color is opaque. Usually the translucent colored ones (light blue/yellow/pink) use a softer, more pliable insulation. I recommend to use a terminal that is sealed and it's insulation is heat shrinkable. This keeps corossion out.
/ Professional electrical crimper #19
<font color="blue">
It's usually due to poor quality insulation on the terminal. Most "automotive" style terminals use a hard plastic insulation which is more likely to crack or harden. These are usually dark blue (14-16ga) or dark yellow (10-12ga). The color is opaque. Usually the translucent colored ones (light blue/yellow/pink) use a softer, more pliable insulation. </font>
Yep - nylon vs. no-name plastic. With crimp connectors, it's worth paying for the better name brands like 3M. Get the translucent stuff - nylon. Better quality, and you can see what you are doing.
Inside a car, weather & corrosion is not much of an issue. On a tractor, it sure might be. Solder & heat shrink is BEST, but a good crimp and heat shrink is also very good. You want the type of heat shrink that gets gooey on the inside when you heat it. Not all does that.
Second the motion on AMP, Paladin, or Klein. Cheap tools are false economy. I'm not familiar with the Snap-On, so have no opinion.
Someone mentioned getting the connector in the right direction - this is critical, and very often overlooked.
If you look into the end of a crimp fitting, you'll see that it is a rolled tube. There is a seam running the length of it. You want that seam at 12 or 6 o'clock with respect to the crimpers. That is, you want the crimpers jaw to come down directly on the seam. Otherwise, the seam is likely to split open, and you'll have a MUCH weaker crimp. You DON'T want the seam pointing to the jaw opening, or back at the crimper's joint.
Attached is a pathetic attempt to illustrate this. The blue is the connector, seen from the end (and without insulation). The red are the crimper's working surfaces. It's a lousy drawing, but perhaps it's enough to show what I'm talking about.
/ Professional electrical crimper #20
Oh bother - the file didn't attach. It was too big. This is great forum (because of the people), but this is sure lousy forum software!
John Deere Gator TX4x2 (A62177)
John Deere Gator...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
