Problems with my Kubota B7800
   / Problems with my Kubota B7800 #1
jmdrewme
Kubota B7800
Hi all. Even though this is only my second post, I read and learn so much from these forums. I have a 2006 B7800 which I love dearly. The other day, the engine started cutting out as I was using it. If I stop quick enough, it will keep running. Otherwise, it would stall. My first thought was the fuel filter so I changed it. But in order to do this, I removed the side panel. It was full of oil. Upon looking at the engine, I noticed a hole blown out on the side right below the injectors! What in the world would have caused this and how pricey is it to fix? Looks like its on a square plate thats bolted on. I am a widow with not much money but I really need to get this repaired. Any help would be so greatly appreciated!! Thanks!
   / Problems with my Kubota B7800 #2
Sorry to hear about your problem. Any chance you can post a picture?
There are some diagnostic/repair gurus on here who I'm sure could steer you right with a little more information.
Hang in there, help is on the way...
   / Problems with my Kubota B7800 #3
I would get someone with a good knowledge of tractors to look at it. If it did have a hole chances are you would have heard it making it! I'd say that the fuel filters is the reason for the power loss unless do to the loss of oil a bearing might have got spun or other type of internal damage.
   / Problems with my Kubota B7800 #4
What state do you live in?
Hi all. first of all, thank you to everyone who replied. I live in Maine. I will post a picture as soon as it stops raining out-hopefully soon. I sure hope someone can help once I post the picture.
The strange thing is, I never heard anything to let me know there was a problem!! You would think I would have. I will post a picture soon.
   / Problems with my Kubota B7800 #7
The plate is the throttle connection. It could have come loose? Look at the throttle linkage coming thru the fire wall for what might be connected on the end. It may be as simple as bolting it back together.
   / Problems with my Kubota B7800 #8
I also looked today and it's like tractorworks said. I'll look at my parts manual and see what all is under it.
Hi again- attached are the pictures of the hole in my kubota. I sure hope its an easy fix but I doubt it. Any help would be appreciated. Thanks in advance!
   / Problems with my Kubota B7800 #10
My looking at the parts, it looks like the injection pump can apart. Have the cam checked and make sure all the broken parts are found.
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52141)
2020 INTERNATIONAL...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
Case IH Farmall 75C (A52349)
Case IH Farmall...
