problems with loader arm
/ problems with loader arm #1
brushcutter01
hi guys
im new in this forum
i plan to buy a new brush cutter
i would to know what you think about the fecon,asv........
i would like to know if any of you had problem with the loader arms ?
do they run great ? any problems with cracks ?
did you ever break a loader arm?
thank you
/ problems with loader arm #2
no first hand experience here...
I wouldn't wory about the loader arms. those brushcutters are much lighter than the loads the arms are designed to pick up.
any vibration stong enough to damage the arms would completely demolish the cutter.
/ problems with loader arm #3
I don't own a PT100 but it is rated for 3800lbs and I think that most of the mulching heads weigh around 2000-2400lbs. I can't see it being a problem.
/ problems with loader arm #4
With proper use there should not be a probelm with cracking the loader arms.The vibration and weight do mean you need to grease more often.Also the weight of the head is enough to stress the machine if you let it drop quickly and handle it roughly.PT-100 is good multi use machine. If all I was doing was mulching I would go with a dedicated machine.That said the PT-100 will do other jobs while the dedicated machine is just killing the grass in your yard when your not using it.Like all machines it depends on the operator.
/ problems with loader arm #5
like said before me. The rc100 is a very versatile machine. I personaly am a asv fan. I have never herd of loaded arm problems on the ash machines.
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
2022 EZ-GO ELITE...
2004 Mack RD690S Tri-Axle Rolloff Truck (A64194)
2004 Mack RD690S...
2011 FORD F-350 FLATBED DUMP TRUCK (A64278)
2011 FORD F-350...
2007 JOHN DEERE 350D LC EXCAVATOR (A65053)
2007 JOHN DEERE...
