problem with starting Massey Ferguson
/ problem with starting Massey Ferguson #1
Gaylee
Lanett, Alabama
Massey Ferguson 1533
My 1533 has always started in all kinds of weather and was used one week ago now it turns over fast enough to crank but won't. I have put a clean fuel filter in and done everything I can think of but the only problem I can think might be causing this is the seat switch. Any suggestions?
/ problem with starting Massey Ferguson #3
Agreed ... If it cranks then the seat switch isn't the issue. Sounds like fuel delivery. Is your fuel pump "clicking" when you turn the key?
/ problem with starting Massey Ferguson #5
How do you stop it, do you pull a lever or just turn the key off, if you just turn the key off check the fuel solenoid.
/ problem with starting Massey Ferguson #6
I believe there is a valve near the fuel filter that can shut off fuel to the engine. Perhaps it got bumped?
/ problem with starting Massey Ferguson #7
I would check the fuel shut off solenoid. Remove it from the injector pump, you'll probably see that it has melted. They are energized to run, and not an uncommon point of failure.
Wagon wheel Table (A64557)
Wagon wheel Table...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A65054)
(INOP)1989 NISSAN...
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
Winchester Sign (A64557)
Winchester Sign...
