problem with starting Massey Ferguson
/ problem with starting Massey Ferguson #1
Gaylee
Lanett, Alabama
Massey Ferguson 1533
My 1533 has always started in all kinds of weather and was used one week ago now it turns over fast enough to crank but won't. I have put a clean fuel filter in and done everything I can think of but the only problem I can think might be causing this is the seat switch. Any suggestions?
/ problem with starting Massey Ferguson #3
Agreed ... If it cranks then the seat switch isn't the issue. Sounds like fuel delivery. Is your fuel pump "clicking" when you turn the key?
/ problem with starting Massey Ferguson #5
How do you stop it, do you pull a lever or just turn the key off, if you just turn the key off check the fuel solenoid.
/ problem with starting Massey Ferguson #6
I believe there is a valve near the fuel filter that can shut off fuel to the engine. Perhaps it got bumped?
/ problem with starting Massey Ferguson #7
I would check the fuel shut off solenoid. Remove it from the injector pump, you'll probably see that it has melted. They are energized to run, and not an uncommon point of failure.
2018 Johnston C201 Compact Street Sweeper (A61572)
2018 Johnston C201...
CSI SLASHER GROUND SAW (A64276)
CSI SLASHER GROUND...
Beverage Truck Body (A61573)
Beverage Truck...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
Caterpillar RM-350/RM-350B/SM-350 Reclaimer Mixer Service Manuals (A63117)
Caterpillar...
2015 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2015 FREIGHTLINER...
