problem with my l35 kabota
/ problem with my l35 kabota #1
jgstang
cool,ca
kabota l35
yesterday i was useing the tractor for about 15min and turned it off to have lunch, well i got back on it and all i get is a clicking noise from a silonoide type deal thats right above the oil filter and thats it! after i turn the key to off about 40 seconds later that same silonoide clicks again and pulls the arm back... i have lights,lights on the dash,flashers,i know the battery is good because i pulled it and put it in my jeep and it started right up. i checked all levers just to make sure nothing got moved so all seems to be good but no turn over at all! i pulled off the starter wires and cleaned them nothing, hit the starter with a hammer a few times and nothing ????? just like that, it has started everytime for the last 4 years.... starter showed no signs of any problems ever ? thanks in advance...
/ problem with my l35 kabota #2
Get your battery checked. My M4700 did about the same, guy at NAPA put a load test on the battery, looked good at first then it failed (really old battery).
Replaced the battery started fine.
Also look at this thread.
/ problem with my l35 kabota #3
Bad/loose connection?? Corrosion along battery cable??
newbury, thanks for that info but the battery in the tractor was installed in my jeep and it started right up.....ok i will look for a loose connection! since i'm running to town anyways i'll have the starter checked..who knows maybe just like that its bad!! i'll update and thanx guys
2020 Kinze 3505 High Speed 6/11 Planter (A61307)
2020 Kinze 3505...
159118 (A60430)
159118 (A60430)
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61306)
2008 Ford F-250...
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
