Problem with Hobart 140
/ Problem with Hobart 140 #1
CharlieTR
NE TX
Long LongTrac
In the Summer I bought a new Hobart 140 Mig/FCAW. I only use Flux Cored.
Used it often with no problems. Now, I think for the first time, I turn it to max output of 4 for the power, and it sputters and spits and outputs a week fizz of an arc. The arc even sounds week! Makes the uglest welds I ever made.
The machine sound be when just trying to feed the wire. It wines and moans trying to feed the wire. Anyone have an idea what I should look for?
Thanks,
Charlie
/ Problem with Hobart 140 #2
What about the simple things like proper drive roller/wire type and size. Tension? Do you have a good ground?
Also, you need to reverse polarity for mig.
Hobart is a quality machine so it's either a lemon or you have missed something simple. It's the simple things we tend to overlook.
/ Problem with Hobart 140 #3
Check the power going to the welder. Are you using an extension cord.Does it weld properly on lower settings. This welder has a 1 year warranty.
Bill
/ Problem with Hobart 140 #4
bad tip? does it feed okay when your just running wire and not actually trying to weld?
/ Problem with Hobart 140 #5
I am also go with "mroldstyle" view....You should first check it that it just give the actual output when you running wire or not.
/ Problem with Hobart 140 #6
It sounds to me like it is either a bad contace tip, or a clogged/worn liner. It might also be that you have the gun cable bent too much.
/ Problem with Hobart 140 #7
I'd remove the tip and verify it is feeding smoothly and also check the dc voltage output. Should be between something like 18 v to 25vdc or so at the various settings.
Most likely a tip, dirty rusted wire. Doesn't take much to stop 20 volts.
Harrell 6710 (A64119)
2002 Ford Ranger Single Cab Pickup Truck (A61573)
2002 Ford Ranger...
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
HARDEE GATOR TAIL PTO PUMP (A63291)
HARDEE GATOR TAIL...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
