Pro Z 960s kw Fuel cap Gasket
   / Pro Z 960s kw Fuel cap Gasket #1
crreed67
Central WV
Massey Ferguson 1635
One of the gas caps on my 2022 Pro z 960 is leaking. Is there anywhere to get just a gasket for the cap or do I need to get the whole cap which is about 42 dollars or so?
   / Pro Z 960s kw Fuel cap Gasket #2
I had one leaking the other day. Turns out I just didn't have it tight enough. Are you turning it tight until it "clicks" a couple times?
I'm not a big fan of the gas caps or the way they're mounted at an angle on these mowers, but otherwise I love the mowers.
   / Pro Z 960s kw Fuel cap Gasket #3
Does the fuel tank vent through the cap or does it have a separate vent? Make sure the vent is clear and venting properly so it doesn't build pressure.
   / Pro Z 960s kw Fuel cap Gasket #4
New enough to be non-venting caps. And to the OP CC doesn't supply a separate gasket for the cap so unless you find a comparible gasket will need to just get a new cap.
Appreciate the help. Yep, 3 or so clicks and as RandyT said non-venting.......So it looks like a new cap.
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
2019 Chevrolet Express (A50123)
2019 Chevrolet...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A53473)
2023 Maxx-D TDX...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2025 Mower King SSRC (A50123)
2025 Mower King...
