Pro Z 960s kw Fuel cap Gasket
   / Pro Z 960s kw Fuel cap Gasket #1
crreed67
Central WV
Massey Ferguson 1635
One of the gas caps on my 2022 Pro z 960 is leaking. Is there anywhere to get just a gasket for the cap or do I need to get the whole cap which is about 42 dollars or so?
   / Pro Z 960s kw Fuel cap Gasket #2
I had one leaking the other day. Turns out I just didn't have it tight enough. Are you turning it tight until it "clicks" a couple times?
I'm not a big fan of the gas caps or the way they're mounted at an angle on these mowers, but otherwise I love the mowers.
   / Pro Z 960s kw Fuel cap Gasket #3
Does the fuel tank vent through the cap or does it have a separate vent? Make sure the vent is clear and venting properly so it doesn't build pressure.
   / Pro Z 960s kw Fuel cap Gasket #4
New enough to be non-venting caps. And to the OP CC doesn't supply a separate gasket for the cap so unless you find a comparible gasket will need to just get a new cap.
Appreciate the help. Yep, 3 or so clicks and as RandyT said non-venting.......So it looks like a new cap.
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
POLARIS RANGER 4X4 PROSTAR UTV (A51406)
POLARIS RANGER 4X4...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
2016 Ford Explorer 4WD SUV (A48082)
2016 Ford Explorer...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
