Pro Z 960s kw Fuel cap Gasket
   / Pro Z 960s kw Fuel cap Gasket #1
crreed67
Central WV
Massey Ferguson 1635
One of the gas caps on my 2022 Pro z 960 is leaking. Is there anywhere to get just a gasket for the cap or do I need to get the whole cap which is about 42 dollars or so?
   / Pro Z 960s kw Fuel cap Gasket #2
I had one leaking the other day. Turns out I just didn't have it tight enough. Are you turning it tight until it "clicks" a couple times?
I'm not a big fan of the gas caps or the way they're mounted at an angle on these mowers, but otherwise I love the mowers.
   / Pro Z 960s kw Fuel cap Gasket #3
Does the fuel tank vent through the cap or does it have a separate vent? Make sure the vent is clear and venting properly so it doesn't build pressure.
   / Pro Z 960s kw Fuel cap Gasket #4
New enough to be non-venting caps. And to the OP CC doesn't supply a separate gasket for the cap so unless you find a comparible gasket will need to just get a new cap.
Appreciate the help. Yep, 3 or so clicks and as RandyT said non-venting.......So it looks like a new cap.
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
John Deere Hayrack (A50515)
John Deere Hayrack...
2017 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2017 GENIE...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
