Prince PTO Pump
/ Prince PTO Pump #1
darinfischer
I have the opportunity to purchase a Prince PTO pump. Problem is nobody has any specs on it. It says Prince C-387 on it. Prince was no help as they didn't know either. Does anybody have one or happen to the gpm of this pump? Any help would be great. Thanks
/ Prince PTO Pump #2
A google search on "prince c-387" turns up and eBay feedback page showing "Prince C-387 gear pump for 540rpm tractor PTO, 21 gpm " I'm not sure how much trust I'd put in that and also I'd be careful buying a pump tha manufacturer can't identify. Probably make ti tough getting parts. Perhapsw Surplus Center can help.
Andy
/ Prince PTO Pump #3
Sounds like it might just be just a casting number... who knows? It certainly doesn't appear to be a current part number.
You will have to go by its dimensions and weight to figure out the exact model. Refer to the PTO pump catalog cuts available here:
Hydraulic PTO Pumps
Note that some pumps have the same overall casing dimensions but different connection dimensions. One way or another, with a ruler, scale and enough time, you should be able to figure it out! :)
Dougster
