Prince autocycle valve
   / Prince autocycle valve #1
escavader
western maine
bx-23 ,
installed on new splitter I've built.its an rd 5000.problem is it doesn't detent either way.and when it gets to the wedge it won't go into relief it already broke a pin in the wedge and I saw it start to bend my cylinder rod but I stopped it in time.
I have the schematic .is it the spool pressure release I try to back off on each?
   / Prince autocycle valve #2
Did you plumb it backwards? If you have the pressure and tank ports reversed it will do what you describe. If it is that way luckily you haven't blown the pump, cylinder or a line.
I plumbed it exactly like the diagram showed.the ram goes back and forth fine ,just doesn't detent or go into relief
I guess I don't understand that part.if I'm not using the power beyond port I can't just leave the plug in it? It doesn't show in the directions to return both to the tank.so am I suppose to t the out and power beyond together and return to the tank?
My salesmen says I don't have power beyond.its capable of it but some extra peice to buy.he thinks it could be I have a few hoses in my plumbing that are two small
   / Prince autocycle valve #8
There are 2 versions of the valve the one without power beyond has just a tank and pressure port. The one with power beyond has 3 ports pressure, tank, and PB if it has the PB port It has to be plumbed to the tank it cannot have a plug in it.
here are the 2 versions
With PB
1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE W/PB | Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Without PB
1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE | Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
You can see the difference in the machining on the side ports.
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
UNUSED TOPCAT 81" HYD HEAVY DUTY HYD BRUSH CUTTER (A51248)
UNUSED TOPCAT 81"...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
