Prince autocycle valve
   / Prince autocycle valve #1
escavader
western maine
bx-23 ,
installed on new splitter I've built.its an rd 5000.problem is it doesn't detent either way.and when it gets to the wedge it won't go into relief it already broke a pin in the wedge and I saw it start to bend my cylinder rod but I stopped it in time.
I have the schematic .is it the spool pressure release I try to back off on each?
   / Prince autocycle valve #2
Did you plumb it backwards? If you have the pressure and tank ports reversed it will do what you describe. If it is that way luckily you haven't blown the pump, cylinder or a line.
I plumbed it exactly like the diagram showed.the ram goes back and forth fine ,just doesn't detent or go into relief
I guess I don't understand that part.if I'm not using the power beyond port I can't just leave the plug in it? It doesn't show in the directions to return both to the tank.so am I suppose to t the out and power beyond together and return to the tank?
My salesmen says I don't have power beyond.its capable of it but some extra peice to buy.he thinks it could be I have a few hoses in my plumbing that are two small
   / Prince autocycle valve #8
There are 2 versions of the valve the one without power beyond has just a tank and pressure port. The one with power beyond has 3 ports pressure, tank, and PB if it has the PB port It has to be plumbed to the tank it cannot have a plug in it.
here are the 2 versions
With PB
1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE W/PB | Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
Without PB
1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE | Directional Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
You can see the difference in the machining on the side ports.
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A53472)
2000 Kenworth W900...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
