Price Check Price matters
/ Price matters #1
oceaneer
Hi I am recently in the market for a tractor, I have never owned or been around tractors so any advice would be helpful. So far I have only looked at a JD 32 hp 4wd hydrostatic, with fel for around 17,000, does this sound like a good price or should I shop around a little.
In my area we also have MF, NH, and Kubota dealers.
Does anybody knows of a good internet site that sells tractors for a good price, if so is that a good idea or should I stick to local dealers.
Thanks in advance for your opinions
/ Price matters #2
Hello...Are you looking to purchase a new tractor? Used? Attachments? What part of the country do you live? Many variables here.
Don
/ Price matters #3
that sounds like a used price on the JD.
what model, how many hours, what kind of shape's it in, etc...
also - what are you wanting to do with it?
all 4 of those are good brands.
/ Price matters #4
Location, location, location
Unless you are in a REAL hurry spend some time here before deciding.
There are so many threads and unlike other things most people have multiple opinions.
Spend some time at each dealership and try and figure out if they are going to be around when you need them down the line. You'll kick yourself if you pay extra for an NH and the local dealer goes out of business. My local dealer for Kubota in Ms. is about to belly up.
I only know of three "internet dealers" I'd trust, but that's only based on a few emails and the opinions here.
good luck.
/ Price matters #5
You can buy many other makes with fel that are around 30 hp/4wd,new,for way less than that. Look at kioti.
/ Price matters
I live in southern louisiana, I plan to use the tractor primarily for mowing, but also for tilling and spreading dirt.
The price mentioned above was for a new JD, 32hp hydrostatic drive with fel. I was primarily looking at new machines because too many variables in used equipment and I know too little about tractors to sort them out.
/ Price matters #7
How much land you taking care of?
fairly flat?
wet?
post back
soundguy
/ Price matters #8
Yeah,I don't like used stuff either.
Think deere may be the most expensive of all? Check out kioti,mahindra and the rest,you should be able to get a 28-35 hp hst tractor with fel for at least a couple thousand less than that deere you looked at.
But if money is no object than deere makes a good tractor,
/ Price matters #9
fairly flat?
wet?
post back
soundguy
I think flat and wet would be a good bet for S. Louisiana.
To Oceaneer, I knew zero about tractors before coming here. Use that search function and you will be amazed at the info here. There are some good people here that can and will answer your questions, just give them all the details and they will help.
/ Price matters #10
Hi I am recently in the market for a tractor, I have never owned or been around tractors so any advice would be helpful. So far I have only looked at a JD 32 hp 4wd hydrostatic, with fel for around 17,000, does this sound like a good price or should I shop around a little. In my area we also have MF, NH, and Kubota dealers.
32 hydro Deere for that price????
What model?
/ Price matters #11
SHOP,SHOP and then make your choice.I would be looking for a local dealer that would support my service & parts needs after the sale.I would also look at how long your local dealer has been in business,do they have a good reputation?Look long and hard,a tractor is a life time investment.coobie
/ Price matters
Model is 3032e,
Land is flat and tends to be a little on the wet side.
/ Price matters #13
OK, I just looked up the specs on the JD - now I understand the price point.
it's cute, and may well do what you want it to do, but I would go look at the Kioti ck30/ck35, Mahindra 3015/3215/3216, Kubota L2800, and/or NH1510 before shelling out the $$ for it.
OTOH, if you really liked it, it's not a bad price and JD usually holds its value well for when you decide to trade up.
/ Price matters #14
We could assume that.. but might be wrong... there are plenty of places in north part of the state that is dry... just about everything south of I-12 is suspect though!
soundguy
207282 (A52708)
207282 (A52708)
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2019 TerraGator 7300 Spinner truck (A63118)
2019 TerraGator...
2024 Honda CRF 450RL, VIN:JH2PD1117RK500228 (A61166)
2024 Honda CRF...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 Better Built 10 ton Gooseneck Flatbed Trailer, VIN 4MNDG2523K1000538 (A61166)
2019 Better Built...
