Pressure washers using cold water
/ Pressure washers using cold water #1
Anonymous Poster
Epic Contributor
Since it's a 30 minute drive to the nearest car wash, I'm thinking about getting a pressure washer. But, the car wash has hot water, so I was wondering how effective one is without hot water. Will a pressure washer still do a good job with cold water?
/ Pressure washers using cold water #2
Danny,
I use mine all the time with cold water and no problems. Just make sure you have soft water as hard water will leave spots if it drys.
/ Pressure washers using cold water #3
Danny, your pressure washer may have almost twice the pressure of the one at the car wash. Be careful! You can peel paint if you get too close. Test it on something or keep your distance from the paint on your vehicle.
JimI
/ Pressure washers using cold water #4
Dave
If you are getting a pressure washer to wash a car,cold water will work just fine.Get a belt driven one if possible they will last longer than a direct drive because of less vibration. I have a little heavier unit than the average,it is sold buy USA pressure systems,it has a 13 HP Honda engine(belt driven) and 4000 psi,great machine,but you can get an adequate one for considerably less. I have heard Karcher is a good brand or Genrac is good too.
/ Pressure washers using cold water #5
I use my cold water pressure all the time. I owned two Sears ones, but they both burned
up. I bought a commercial one for about 600.00. I do lawn mower repairs & use it all the
time. I keep my JD 955 looking like new when I'm done mowing. Gas ones are good too, but
I find the electric is alot more handy. just flip the switch & your washing. Also in the winter
you don't have to worry about the fumes, if your using it inside the garage. Remember if
you live in a below freezing area to drain it when your done.
Molerj, What model of Sears ones did you have? Were they the electric or gas ones? I'm considering the gas model 4000CP. I like the metal wand vs the plastic one like some others I've looked at. It seems like all of the electric ones have plastic wands and the hose is not very long. What brand do you have now and where did you get it? By they way, the reason I'm so hep on a metal wand is because I want to be able to unscrew it and put a flexible hose on it like they have at the self server car washes.
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
213135 (A64276)
213135 (A64276)
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
CLUBCART CART (A66091)
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
