Pressure testing difficulties
/ Pressure testing difficulties #61
JJ,
Thanks for the advice. Would you happen to know how long Northern Tool will accept exchanges? I still have all of the original packaging but I have had the valves for some time...just never got a chance to get started on this project.
Also, you had mentioned going from the last subplate T port to the 3pt IN port. Would this be the same as the PB port on the hydraulic block as this is where that last PB hose terminates?
/ Pressure testing difficulties #62
Yes, that is correct.
/ Pressure testing difficulties #63
I have been reading quite a few of your replies on the subject and I need some clarification on the nomenclature. You have mentioned upstream and downstream in numerous posts and replies. Considering the layout that we have been discussing where you have the pump, block, FEL, and lastly the BH; is the block upstream of the FEL and the BH is downstream of the FEL with the pump being the source?
/ Pressure testing difficulties #64
Yep, the hyd block is in the middle. Some tractors have them and other don't.
The hyd blk is a distribution assembly. The pump flow passes through the hyd blk and goes o the FEL,
The FEL returns the PB to the hyd blk for downstream valves, remotes, BH or 3pt.
The other stuff you said is correct.
/ Pressure testing difficulties #65
JJ,
I have been going over some of the things that we have talked about and the advice given thus far and there is one thing that I cannot wrap my head around.
When you say open center do you mean a true open center where all of the ports are interconnected in the center position or a tandem configuration where the P and T ports are interconnected in the center position?
When there is a relatively unrestricted flow through the system as with an open center system what is preventing the complete loss of pressure on the T side? Is there some sort of restrictor that provides some sort of back pressure? Even if it is only 50# or so?
/ Pressure testing difficulties #66
Granted I'm not J_J but one can't successfully have a "T" in an open center hyd system. Every component must be attached in a series from pump to sump.
/ Pressure testing difficulties #67
On a valve without PB, the flow is IN port to tank port to reservoir.
The tank port on most valves are not rated for high pressure, only about 500 psi, and the presumption is that it will be the last valve in the flow path. Both pump flow and cyl flow pass through the tank port.
Nowadays, most new tractors have a dedicated high pressure port called PB for power beyond.
The tank port on new valves is for cyl expended flow.
So in an open center hyd system with remote and hyd blk, the flow path would look like this.
Pump, to hyd blk, to FEL, FEL PB back to hyd blk, to remote valve, to 3pt, to tank.
All tank ports can be teed .
If you have a BH, it plugs in after the remotes. If the BH has a PB port it can feed the 3pt. If it only has two hoses then the tank port goes to tank. You don't need the BH in most cases.
You don't want back pressure.
Running the tank port to another valve is never a good idea.
What you want is a one direction flow from pump to tank through all valves.
The first valve upstream that fully uses all the fluid leaves no for downstream operation.
The valves redirect the fluid to different hyd circuits.
/ Pressure testing difficulties #68
Okay so I completely disconnected the remotes from the hydraulics and connected the P back into the PB. However, I did install a TEE with a gauge to check the pressure and, just as before, the only time that I measured any real pressure was when pressure was directed to the 3pt hitch. I also hooked the gauge to the QC on the FEL connection as shown in the video at the beginning of this thread and read 2200 psi when engaging a function. This seems somewhat illogical to me. Can one of you help me understand what is happening that is preventing any real reading of pressure on the PB from the FEL to the 3pt?
/ Pressure testing difficulties #69
I will tell you this, if you install the gage in a tee in the IN port of the FEL valve, you will read the pressure of any valve that is used .
I recommend doing this as a monitor and trouble shooting aid.
If a hyd gage is installed in the flow path, and you use the 3pt, you are reading the pressure that the 3pt cyl is developing.
If you have a gage installed downstream of the FEL, you will not read the FEL cyl pressure.
/ Pressure testing difficulties #70
JJ, is the PB on a FEL valve considered to be "downstream" or will it also read the loader pressure when used.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
