Pressure Gauge Question
/ Pressure Gauge Question #1
NCMau
NC
MF 202/Ford 8N
I am in the process of modifying my tractor with a PTO hydraulic pump. If I were to install a permanent pressure gauge in the system, would the inlet of the control valve with a T be a good choice?
/ Pressure Gauge Question #2
That would be the perfect place for it. Be sure to use a Tee rated for the pressure (and not a cast iron plumbing one from Home Cheapot) and gauge rated for 3k or 5k PSI.
/ Pressure Gauge Question #3
liquid filled gauge too!
/ Pressure Gauge Question #4
As kennyd says get 3-5K psi guage. It is said a guage is most accurate in the center of it's range, hence if you expect 2500psi get a 5Kpsi guage. On the other hand the graduation will be further apart on a 3Kpsi gauge than a 5Kpsi guage so it might be easier to read. Either will work.
Thank you guys. I am totally redoing the loader hydraulic and I am surely going to have more questions in the near future. One that comes to mind is the drainage of the external tank (located behind the seat). Although not absolutely necessary, I am thinking it maybe important to have one to avoid uncoupling the lines for fluid drainage purpose. Maybe T the return port of the tank?
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
