Mowing Predator 2 Blades
/ Predator 2 Blades #1
Piedmont
NC, USA
JD 2520
I'm installing Predator 2 blades on my 62 d deck, does anyone have an opinion on whether or not I would still need the mulching kit that JD sells or would the blades surfice?
/ Predator 2 Blades #2
Those kinds of blades are not meant to be used with a mulch kit. Those are very similar to oregon G6 and G5 blades (though not as good as the g blades are), and Oregon has said many times over that they are for side discharging only. I use the G6's under my Z950 deck for part of the season (I mow for a living) and have for the last 3 years since they first came out so I do have some experience with them. IHTH
/ Predator 2 Blades
Thanks RG1, I appreciate your feedback.
/ Predator 2 Blades #4
The gator type blades will just make a gooey mess under the deck and leave clumps on the surface when used with a mulch kit unless you are taking off less than 2" and/or the grass is very dry.
With a mulch kit, the OEM wavy mulchers are almost impossible to beat. I use them even when side discharging most of the time, under my Z950 and my old 240 and 4115 w/60".
/ Predator 2 Blades #5
I just installed a set of Predator2 blades on my 42" D110 deck. The original blades had lasted 2.5 years and had been nearly destroyed due to using the rig to primarily finely break-up the horse 'droppings' in my paddocks (after first chain-harrowing). The ground is sandy but is getting very rich via this manure spreading method.
I am very impressed with these blades. A clean cut and the discharge distance has trebled! A$65 for the pair + my local Dealer said I should get double the life out of them.
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A66736)
2020 Chevrolet...
Unused 2023 USA Manufacturing Hydraulic Thumb Excavator Attachment (A66734)
Unused 2023 USA...
2004 POLAR TANK CRUDE PUP TRAILER (A67714)
2004 POLAR TANK...
HYUNDAI HL955 WHEEL LOADER (A65056)
HYUNDAI HL955...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
