Pre-filtering fluid
/ Pre-filtering fluid #11
Companies like Parker, Hydac/Schroeder, etc. all make filter carts like the Scooby posted the picture of. And new fresh oil is not necessarily all that clean. A couple of years ago I worked with an oil supplier on a filter system for filtering from batch mixer into 55 gallon drums. Some oil manufacturers or distributors require certain ISO cleanliness on their oils and others don't.
/ Pre-filtering fluid #12
Any machine that has hydrostats or high pressure piston pumps needs oil to be prefiltered if they don't have filtration on the suction side. Even if they do it is good practice. A easy way to do this is add a filter head on the discharge side of your pump. It can be done for about $40 to $50 dollars. I don't worry about gear systems as much but if my customers do not prefilter oil, their warranty is void. I will gladly let them use my pump systems to avoid this. CJ
/ Pre-filtering fluid #13
At Caterpillar - our large cold planers (for milling the asphalt off roadways) had a pre-filter package. Pour the oil into a fill reservoir, then operate a hand pump to filter the oil fine enough to meet all the piston pump and motor requirements. Added expense but worth it on a machine with so many hydrostatic drives. We test cleanliness of every hydraulic system before shipping - if it fails it needs to be attached to a kidney loop machine for extra cleaning.
+1 Schramm and a few other manufactures have prefilter systems or some way of cleaning any oil added just for this reason that you stated. A lot of the harvesters we have around here are now running 3 micron off line filtration with great results. The old thinking with gear pumps a 2000psi and no filters is long gone on a lot of modern equipment, now the ones who know have to help change this way of thinking with the new equipment. CJ
Awesome idea! $40-$50, heh? Can you tell me what filter assemblies you are referring to? I guess I don't know what I am looking for as the ones I find in that range are only rated for the suction side.
Filters on my machine are getting increasingly hard to find. If I can add one or more currently available filter head(s), I prolong the life of the existing really hard to find and expensive filters, especially if I put a gauge on them to determine when they are clogging up.
How can I determine the GPM capabilities of the current pump so that I can get a properly-sized solution?
Also, there appear to be multiple outputs on the pump - or maybe even sub-pumps (I don't actually know what I am looking at, but see multiple hoses leaving the pump area with varying diameters - three 3/8" lines, one 3/4" line, and one 1" that I recall - going either to different filter assemblies or, in the case of the 1" line, out to the valves directly).
I have what sure looks like a canister pilot filter, a canister swing filter, a spin on filter that attaches to the outside of the hydraulic reservoir, and an in-reservoir filter that I have found thus far. While I have filtration on the suction side via the in-tank filter, it would be incredible to at least filter the line leading to the valves with a 10 micron filter. If the filter head had a separated port, I could then add in a much finer maybe 2-3 micron filter as a bypass type as well.
/ Pre-filtering fluid #15
HOLD ON NOW. I was referring to your transfer pump, we were talking about prefiltering oil, not the pumps/hydrostats on the machine. That as you know has to be sized to the pumps. With the hydrostats having suction filters and the open loop pumps having return line filters. I have been building return filters into the tops of my reservoirs also lately. IMHO over filtration is better than under. I have also been putting pressure filters inline with the hydrostatic loops, this has been quite effective in stopping the loss of the hydrostat when the motor fails. CJ
/ Pre-filtering fluid #16
I've got some experience with the old Koehring excavators from the late 70's. They had cutting edge hydraulic technology for the time. They were very sensitive to hydraulic oil cleanliness. I would follow the recommendations of the manual. At this point, failures due to contaminated oil could result in expensive issues since these excavators are no longer in production.
Also, I've seen some recommend modifications that add additional filtration to the unit. This should only be considered by those very experienced in hydraulics as a mistake could be very costly.
I hear you loud and clear. Trouble is, finding filters for this machine is getting impossible. I figure that my adding auxiliary filtration, I lengthen the life of my impossible to find filters. Of course, I need to ensure that I use the proper filter assembly and filter - I can't be starving the valves. Current thinking is a duplex filter like this 50gpm-rated one with 8" filters: http://www.donaldson.com/en/ih/support/datalibrary/063509.pdf
/ Pre-filtering fluid #18
Get you filter ###'s and call this place 800 285 5364. I am almost 100% sure they can help you. You may have to send them a sample but they can do just about anything when it comes to filters. You would be talking some major $$$ to refit equipment on filtration. I do it quite a bit and it usually is more cost effective to find or build different elements. CJ
/ Pre-filtering fluid #19
Seems to me that if you can find the return line to tank you could do almost anything to filter, from adding a double filter to adding a by pass filter using a filter element of 1 micron.
The particles greater than 10 micron may cause problems, but people forget that the smaller particles less than 10 microms are what causes the wear, rubbing, polishing on hyd parts causing loss of pressure capability.
Inline filter for that kind of flow would be very expensive.
So some good return line filters from each hyd circuit returning to tank would be ideal.
/ Pre-filtering fluid #20
I can tell you from personal experience that "we engineers" are not making this stuff up. I have personnaly added 5-6 barrels of a major brand high-end hydraulic oil to a brand new system. As I was getting to the bottom of the barrels I was looking in with a flashlight to see how much was left and was startled by how much crud was floating in there! If I can see it from 5ft away with a poor flashlight there is no way in **** that it is even filtered to 100 micron. It made a total believer out of me. (I think buckets are cleaner, but I have no personnal experience to say for sure)
I agree with JJ about fine particles being a major contributor to wear. I would caution about going much below 7-10 micron filtration for fear of stripping out some of the additives (especially with gear lube). You also would need much larger filters to keep the backpressure reasonable and prevent bypassing when cold.
As far as the filter carts go I have bought one and I've made one, both work the same. My ideal filter layout would be a mesh screen to catch the big chunks, then a ~25 micron feeding a parallel set of 7-10 micron filters. One thing to watch out for is keeping the outlet side clean. It doesn't make much sense to scrub the oil to then use a dirty wand/connection to put it into your system.
ISZ
2011 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2011 HEIL TRAILER...
SANY SY35U EXCAVATOR (A59823)
SANY SY35U...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
UNKNOWN TANK MANIFOLD (A60736)
UNKNOWN TANK...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
