Powerstroke question....
/ Powerstroke question.... #41
did his input shaft shear off? guy i know that pulls horses with me had his shear off.
soundguy
I guess this about the Dmax. No, 2 fluid leaks this time. Tranny cooler lines are pissing pretty good and its time for me to do a real fix, not the crappy GM fix. I will use hydraulic hoses to get it right.
The other issue is the rear main seal is leaking pretty good. Its losing a quart a week.
Chris
/ Powerstroke question.... #42
I have been working in dealers for almost 11 years now. I see the overall trends. Not case by case.
I'd take the Allison over any of them any day. The new 68RFE is a close second. I'd take the ~'03 48RFE Dodge trans over the TQS or 4R100 Ford for reliability every time.
/ Powerstroke question.... #43
Chris
hmm.. reminds me. I saw a drip or two of red on my driveway from my 350 the other day.. need to get under there and see if it is a ps or tranny issue. might be a cooler / line etc... fun fun fun.. :)
soundguy
/ Powerstroke question.... #44
Dargo said:
It appears for all who have owned them, you have your transmission years backwards. It was the pre-6.0 liter transmissions that constantly had issues. I'm yet to run across anyone I know with a 6.0 PSD who has had a transmission problem.
The obvious joke here is... How can you ever hurt the transmission if your engine never runs?
xtn
PS - my 03 6.0 has 197K miles so far without issue.
/ Powerstroke question.... #45
I'm surprised about the 4R100 vs dodge comment, that dodge transmission is better than the older ones though. Both are poor for reversing heavy loads, and one year of the Ford transmission had a stupid mechanical fuse that was a bad idea. The 4r100 does seem to last through more abuse though, from snowplowing to towing.
I'm guessing mine will live forever as it only has the 2v 5.4 V-8 in front of it.
/ Powerstroke question.... #46
the fuse that you call it is(was) a mechanical diode that ford has used in both the 4R100 intermediate sprag and 4R70W. it was common knowledge NOT to use the one in the 4R100. ford has also used a sprag and spring+roller OD overrunning clutch. I have seen more of the later spring+rollers type fail than the older sprag type. another failure in the E4 OH NO was lack of lube in the forward planetary and converters also especially with the diesel as the torque would pull right through the clutch and massively over heat the trans.
/ Powerstroke question.... #47
Wasn't that thing only 4 elements? Been awhile since I've been in one with the intermediate one-way.
Not to mention that every bit of metal ends up in the valvebody or accumulator body.
How 'bout those Ford torque converters? The 4R100 was an improvement, but then again anything was better the what the E4OD had.
Atleast the AOD is a pretty slick design.
/ Powerstroke question.... #48
Like most things, not so much a problem until you start increasing the torque of your diesel. I would have loved to get a truck with a ZF-6 in it, but they are so very rare. I never actually saw on in my year of looking.
The mechanical diode is only on early '01 trucks. It was a dumb idea that almost always meant a catastrophic trans failure.
I found a 2001 w/7.3 automatic. Seller says have had good luck with trans, but they only put 25,000 miles on it since they bought it '07. it now has 168,000. How do i determine which diode it has, I assume by manufacturing date. Anyone know where the cutoff is? Also, any idea of what i else i can look for problems? Horse people has the unit, so it's not from a hotshotter. Truck looks clean from the pics. getting close ups of a few areas tonite. New way to buy a vehicle, i am in Maine this truck is in the south.
/ Powerstroke question.... #51
it was used in 2000 - 2001 years and was a totally different design from a overrunning sprag. it sounds more like a ratchet when you turn it buy hand. ask if it has a performance chip and exhaust work as these mod's are hard on a stock trans if it was used to pull heavy.
Thanks for the info. No performance chips, still stock. That was one of the first questions i asked.
/ Powerstroke question.... #55
The only small flag i would have if it's exhaust with a ECM thats been chipped.
Many companies make programmers that are "phantom" programmers. It's not 'chips' that really make the truck go, it's custom programming through tuners. I can tune the living **** out of my truck, and have, yet take it in for a small oil leak under warranty and there is zero sign of any tune ever being on the truck. It all boils down to how much you trust the fella telling you that it has never been juiced. I've posted video's of my 8700 pound 4X4 dually diesel running in the high 12's in the 1/4 yet in about 2 minutes I can remove any fingerprint that it's ever been worked on.
Internally on mine I've added ARP headstuds, or it would have blown the heads right off the engine, but unless they take the engine apart, that wouldn't be seen anyway. Besides, even if they did see it, that would only assure them that the chances of my truck blowing the head gaskets would be almost nill.
/ Powerstroke question.... #56
when you do mod's that increase the torque output of the engine and any kind of chip (programer ) along with EXHAUST will do exactly that. on the ford's of those years the down pipe from the turbo is a pretty good restriction. removing it WILL increase torque and more torque is more strain on the tranny.
Exhaust work has nothing to do with the transmission.
/ Powerstroke question.... #57
Another case of people not knowing what they're talking about. The powerstroke history is too complicated to just guess about.
The OP asked about powerstrokes from 98 and up. Ford didn't make a 98 model so 99 is the first year of the powerstroke in question. In late 2003 they went to the 6 liter trucks so we'll have to assume that the OP wants a 99-2003 model which would qualify as "older". Well, these trucks never had a smashed downpipe like the older pre99 non super duty powerstrokes that Bill50 must be remmebering. The only exhaust restriction in the super duty's system is the muffler and even that restriction only resulted in higher EGTs when the power was increased through a chip.
I have actually replaced the exhaust with a performance system on my superduty powerstroke and I can verify that the only change was sound. Anybody who knows diesels knows that exhaust upgrades are considered supporting mods which simply allow you to safely increase the power but do not make extra power themselves.
Do be afraid of chips. You can be suspicious of a truck's chip history if supporting mods are evident such as gauges, exhaust, or a fancy air filter. These supporting mods alone are actually good to see but if you find the actual chip or even holes drilled into the dash then I would walk away.
An exhaust system alone on a 7.3 powerstroke has never hurt anybody's transmission, that's just silly and an obvious grasp at straws.
/ Powerstroke question.... #58
I couldn't agree more. I've been working with 7.3 liter Powerstokes since 1996. It's not that the chip in and of itself is bad. They can safely improve fuel mileage to a degree (not enough to justify the $400.00+ cost), and engine performance. However, the odds are Grandpa didn't buy a chip to haul his cattle to the sale barn. Odds are, some 18-20 year old put a chip in it, then dogged the crap out of it running around town, blowing black smoke out the exhaust at stoplights and drag racing it. While that isn't -always- the case, 95% of the time it is.
I personally would avoid any 7.3 liter truck with an aftermarket intake, aside from the Ford factory Severe Duty Intake, or a big paper filter. I've seen every other type of reusable air filter let dirt into the engine, some more than others. The Ford Severe Duty Intake (AIS) is the best intake kit you can get in terms of filtering performance, and it flows better than the standard filter as well. You can tell the difference by looking- a standard factory filter will cover the driver's side battery with part of the plastic housing, and be a flat, rectangular filter. The Severe Duty intake will have the driver's side battery exposed, and be an oval shaped filter.
Been a heck of a thread for me. Hopefully one of you two can respond before i leave. I plan on being in Atlanta fri am(flying out thurs pm). Looking at a couple of different trucks. My preference is a 2000 250 crew 7.3PSD. 260,000 miles( a little more miles than I would like), but it has a "Diablo" something or other for the shift points of the tranny? Any concerns?
All the pics i have shows it as a clean looking unit, w/5th set up. Offered $8,000. he's chewing on it. was asking $9700. carfax and title search thru georgia are clean and verify's what he's telling me. NADA and KBB is listing as $11,500 to $12,000.
plan on picking up a Kaufman 24ft gooseneck up on the way home(saves $500+ shipping). Will be doing some local hauling for the Amish. Might click out 15/20,000 miles a yr.
/ Powerstroke question.... #60
...it has a "Diablo" something or other for the shift points of the tranny? Any concerns?
Big one for me. Diablo is a performance tuner. I believe it was one of the early ones for the 7.3, and they were a bit more dangerous to the engine with regard to EGTs (exhaust gas temperatures) than newer chips/ tuners. The only way to safely operate a chip or tuner is with gauges, specifically EGTs, and transmission temperature for an automatic. I'd be leaning away from it already, if there are no gauges then I would pass. The previous owner could have been abusing the truck and not even realizing it.
Is it the original transmission? A good rebuild will cost you $4-5,000.00. Considering it's been chipped, and used for towing, I would expect transmission problems in the near future, if they aren't already there.
If the truck blue books at 11,500, and a transmission is 5,000, then that means you'd have more in it than it's worth if you paid more than $6,500-7,000.00 for it, presuming there are no other issues. At that mileage, I would expect other issues. Check the front end well, tie rods, drag link, and ball joints.
Is it a 250 or 350? 4x4? Dually?
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63118)
2008 Ford F-250...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
Cat 3-4 quick hitch (A64047)
Cat 3-4 quick...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2007 DRAGON 130BBL STEEL (A63569)
2007 DRAGON 130BBL...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
