Buying Advice Powerstar T4.75
/ Powerstar T4.75 #221
Utopia Texas where did you get your monitor bracket? Also does it bolt to the cab pillar as well? It was a year or so ago now I asked my dealer for one and they did not show one available. Thanks!
The "L" shaped bracket that goes from the top of the door to the door pillar is a New Holland part. Take a copy of my picture to your dealership and show it to the parts guy. He can take it from there. Go to your local bank first and float a small loan for the bracket! :) Yes, There are metal cap screws that hold the bracket to the door frame. The threaded female parts are already in the top of the door and the pillar but may be hidden by plastic upholstery caps.
/ Powerstar T4.75 #222
eth555, I think the part you are looking for is 87614599. You can go to new holland's parts site and look it up by part number to be sure. If you want to see a graphic of it it is in the platform, cab,decal section, it's listed as "support, monitor" or something like that.
I understand your frustration about not finding what you want at a dealer. I've been trying for 2 months to find a 3rd function diverter valve kit part number unsuccessfully, I know they make them, utopia Texas has one on his. So if anyone can help me with that I'd sure appreciate it.
Wayne
Ps here's some more info.
15 SUPPORT ASSY, Incl 7 - 14 87614599 $190.89 3-7 business days
/ Powerstar T4.75 #223
Wayne
The 3rd function valve on our T4.75 was added at the dealer when we purchased it. I believe it's an after market valve sold by W. R. Long. Check out their website Valve Kits They sell it in a kit form with all fittings and brackets you need. There are plenty of other companies that sell them also.
/ Powerstar T4.75 #225
Thanks guys, that's what I was wanting to know. I hoped New Holland had an off the shelf kit so it would be a plug and play installation, and one of these WRlong kits or others may be. My tractor has switches on the joystick and wiring ready to hook up, I don't want to start cutting and splicing wires on a brand new tractor if I don't need to.
I appreciate your response. Looks like I'll be ordering an aftermarket kit.
Wayne
/ Powerstar T4.75 #226
Wayne Clagg and Utopia Texas, Thanks for the information and part number. Wow almost $200 Utopia Texas is right I need to stop at the bank first. I may try to fabricate something for that amount of money.
It sure seems like New Holland would offer a plug an play kit for our tractors to add a 3rd function; it is probably just talking to the right person at the right place like with this monitor bracket. I thought I read in the brochure (it has been a long time) that there was a dealer installed option for that? I will have to go back a reread that when I get a chance.
/ Powerstar T4.75 #227
About a month after I bought the bracket from my New Holland Dealer I happened to be on EBay and typed in "monitor bracket". At that time there were a lot of options there that were very inexpensive.
/ Powerstar T4.75 #228
Just an update for any who are interested. Looked at a couple kits and emailed Iowa Farm Equipment. Told them what I had and they responded shortly with a price for a plug and play "true" 3rd function valve kit for $975. This kit is supposed be a bolt on affair that will plug into my existing wiring harness "as long as I have the two red buttons on the joystick", which I do. So if anyone is interested in how this works out let me know and I'll post an update when it comes in.
/ Powerstar T4.75 #229
I had the WR Long 3rd function installed on my T4.95 when I bought it. It appears to be a very simple and clean installation. I have not used it yet, so I can't comment on its performance.
/ Powerstar T4.75 #230
I'm interested to see how it works out. Keep us updated.
/ Powerstar T4.75 #231
The kit came in yesterday and guess what. It was a WRLong kit. Laid everything out, got familiar with all the parts and got my bearings on installation.
Here's a few observations. The kit is high quality and really complete. The instructions would be hard for someone with limited skills to understand and easily complete the installation but I was able able to figure it out in short order. The only disappointment is there is no connector to plug into the joystick switch and it will require cutting the 4 pin connector off the end of the wire coming out of the handle. I had hoped it would be a plug and play installation with just a hot and ground wire to connect but it's not. This will require finding out which wires do what with an ohm meter but shouldn't take but a few minutes. However, it comes with a wiring diagram and after a few minutes of study I was able to get the required plan together. I would estimate 2 hours at the most to install.
I have spent the day looking for a switch that will match and snap into the command arc console and allow me to turn the valve circuit off when not needed so as to prevent inadvertent operation. I'll take several pictures of the installation for anyone that are interested in seeing them.
Wayne
/ Powerstar T4.75 #232
Update. I will be tradeing off my 75c. Only 61 hours on it, spent more time in shop than in my barn. I would recomend buying anything other than the powerstar line of tractors.
i'm about to do the same 2015 t4.75 with 27 hrs on it it leaks oil water and fuel it had 4.5 hrs when it arrived at 7hrs all the problems started. the dealer fixes it in a few hrs its back to leaking. on top of the leaks when i put it in park the dash lights go out and the engine revs to the red line and about a few seconds later it all goes back to normal.
/ Powerstar T4.75 #233
Do you know anything about the mahindra 5570? They are not supposed to have the DPF? Can you give me some info on these tractors?
2014 Nissan Altima Sedan (A61569)
2014 Nissan Altima...
GMC 2500HD 4wd Service Truck (A63118)
GMC 2500HD 4wd...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2019 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2019 East...
2025 X39 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 X39 Hydraulic...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
