"Powersafe" clutch on BCS
/ "Powersafe" clutch on BCS #1
Bentleg
Bronze Member
BCS 710
Ran across this. Here's a U-Tube video with pretty music...[ame=http://www.youtube.com/watch?v=yiC9AedkFf0]BCS SISTEMA POWERSAFE - YouTube[/ame]
It seems to satisfy some new European safety standard. Its a hydrolic clutch that releases when you release the deadman lever. The motor keeps running but the wheels and implement stop immediately. Supposed to last forever. I like it.
Wonder it we will see it in the US....
/ "Powersafe" clutch on BCS #2
Hey Bentleg,
Unless the US goes toward the same rule, you'll never see the hydraulic clutch in the US. It adds considerably to the cost of the machine.
Bill in WI
/ "Powersafe" clutch on BCS #3
Not sure what that gets you that shutting the engine off (like BCS Dad has does) doesn't.
Aaron Z
/ "Powersafe" clutch on BCS #4
This meets a European safety standard. It doesn't apply to the U.S.A. Stopping the engine does the same thing but it's a European thing (shrug here).
Jim
But the whole concept of a well built 2 wheel tractor is an European thing. The US makes nothing comparable.
/ "Powersafe" clutch on BCS #6
Hi! The Powersafe clutch. on BCS are not Hydrolic. This clutch is a multi-disc in oil bath. The handle with two cables drive a cam for press the multi-disc. The multi disc clutch in oil bath casing is very small. Very good Innovative ! I like it. This one is available on BCS 750. I think soon here in America . Good Luck! Oldmech
/ "Powersafe" clutch on BCS #7
The wet clutch models are available in the US and Canada for 2012.
The new models are the 740 (similar to the 853 and a 750, which is more in line with a 948
Have fun, oh and BCS know has new Literature showing the new units!
/ "Powersafe" clutch on BCS #8
Hi! I must to apologize here! Because I was wrong. I go on BCS web site. bcsagri.it . This mutidiscs clutch use hydraulic pressure with pump and oil filter . Very innovative. More safe for stop with Diesel engine. Can take some or more energy from engine I like less now Also . May be some trouble later. In Europa Bcs sold now 710-720-730-740-750 model with Powersafe Price look not very high . In these countries a new safety law is coming. Thanks and good luck! Oldmech
/ "Powersafe" clutch on BCS #9
I wonder if the hydraulic supply for the clutch has additional available "umph" for powering a small hydraulic attachment? If so, then we can possibly mount some low power movement type attachments.
Bill in NC
/ "Powersafe" clutch on BCS #10
What would you move?
Would you change the tine depth on the tiller or adjust the cut of the flail mower or the R2 rotary harrow?
jim
/ "Powersafe" clutch on BCS #11
New Models this year??? Any dealers know when the updated website is coming out?
/ "Powersafe" clutch on BCS #12
I know BCS America is working on it, but a "new" website will be several months out. I have been told the 740 and 750 will be added to the existing website in the next few weeks.
/ "Powersafe" clutch on BCS #13
What will be the updates to the 740 and 750?
Maybe a lower price???? Lol
/ "Powersafe" clutch on BCS #14
Hi! I make some search. I find New 740 powersafe (Look as 853) have 3 speeds front and 3 speeds rear instant reverse but NO MORE road high speed. as 852-853 . The new powersafe clutch is 5 years warranty. A new Yanmar diesel engine LN100 (LN for low noise) is available. Good Luck ! Oldmech
/ "Powersafe" clutch on BCS #15
How low noise is the new yanmar
You guys that have a diesel... how long do they run on after you release the dead man lever?
/ "Powersafe" clutch on BCS #17
I would like to know if the 740 would have a high mowing speed like the 750.
I cant find anything online.
/ "Powersafe" clutch on BCS #18
Hi! If you ask for new range BCS Powersafe. I am going from bcsagri.it .
The new 750 have reduction gear as 948. Speed 3+3 Front .98-2.27-3.34 Reverse 1.03-2.39-3.51 Look as No More road speed
740 Speed range 3+3 front 1.26-2.92-4.30 reverse 1.33-3.08-4.53 Look as no more road speed. I think these speeds are in Kilometer. The 740 as 853 have in reverse more suitable speed for mowing. Good luck ! Oldmech
/ "Powersafe" clutch on BCS #19
The "dead-man switch" on the Power Safe models (740/750) no longer kills the engine, just disengages the clutch.
This is great, due to both transport gears and the PTO is stopped quickly, with no need to restart the engine!
/ "Powersafe" clutch on BCS #20
Actually i meant if the 732 would have a mowing speed, sorry
