Power Trac Update
/ Power Trac Update
Tractorgolf:
The only implement I have of that type is a york rake that I made myself. They do not sell one, they sell a power rake wich is supposed to be very good. I have never used a power rake but some of the post I have read say very good things about them. I think with the rototiller you would could go forwards? My rake works excellent in reverse ONCE YOU GET USED TO IT. Backing up a articulating machine is a completly different feeling and you need seat time to master it. Having the implement in front of you has the advantage of being able to add a lot of down force quickly and removing it just as fast. The rake has worked well, I saw the box blade and don't think it would work well in my area. It is very rocky in this part of CT. The hydralics work very quickly and are extremly strong.
/ Power Trac Update
Kcook:
The bucket has been great, it is rated for 800lbs but I have had well over that in it. I have not lost traction but have had a big enough log in the bucket that it lifted the back completly of the ground, while this sounds dangerous it is not. The machine remains very stable still. Because of the speed of the hydralics and shape of the bucket with teeth I now pick up logs in the bucket with out leaving my seat, no chains required.
Moving snow with the plow was easy unless it was over a foot and you where on gravel, it still worked well but took more work. I was wondering if I would need chains but after a record year for snow I don't think I will.
The only problems I have had are a blown fuse for the fan after I wedged a branch in it, I repaced the fuse and it was just like new. I cleared a large parking lot of it's snow banks and after about 3 hours of hard use the tractor made a high pitch noise. I called the company and they explained to me that some times a very small piece of slag from welding the tank gets by there cleaning process and when it gets to the filter you can hear it. They told me how to change the filter (wich they include a spare) and bleed the system. It took about 5 minutes and I have not had a problem since. (60 hours later)
There are distinct differences between the three models:
The pt418 has a Robin 18hp motor with no external fan or oil cooler.
The pt422 has a Robin 22hp motor with an external fan and oil cooler.
The pt425 has a Kohler 25hp motor with an external fan and oil cooler, it also has a roll bar and 3/16 inch steel rain cover.
I chose the pt425 because of the roll bar and the Kohler motor wich is reliable and any small motor repair shop will work on.
I got my tractor stuck in the mud the other day and rememberd what a friend of mine told me about articulating loaders when I mentioned that I had a machine that articulates. He called it waggling. You just turn the wheel from one side to the other and the machine just crawls out.
Yes the attachments are as easy to put on as the adds say. You only have to get off if your implement requires a hydralic hook up. (quick connects)
Let me no if you have any other questions, Rich
/ Power Trac Update #23
<font color=blue>He called it waggling. </font color=blue>
Rich, I guess thats as good a name for it as any/w3tcompact/icons/wink.gif/w3tcompact/icons/laugh.gif
I once saw a guy to that with a Cat 988 loader. He was trying to clean out a muddy creek when he got stuck. Since he was in mud up to the middle of his hubs and had to climb a bank to get out, I bet his foreman lunch he couldn't do it. I lost. But it was worth a hamburger to see that monster crawling out of that mess.
Ernie
/ Power Trac Update #24
WillingtonPizza,
How did you get your Power Trac, did you have to pick it up, or did they deliver? What attachments did you get? How is the company to work with? Any advice for a possible new buyer?
Thanks,
Kevin
/ Power Trac Update
I had them ship it with a private shipper, it cost me $900. They were great to talk with and there service department was very good to talk with. I got the snow plow small bucket with teeth and the 60" mower deck, they all work great and are built excellent. I made a york rake for it. My next three purchases will be a brush cutter, stump cutter and a power rake (harley type). Will have to wait until the end of summer, we are building a barn right now and I can't swing the extra dough till then.
I don't know where you live but if you can get to the factory they will give you a tour of the facilitie, give you a maintnance class on there machines, let you try various tractors and put you up in a hotel for free.
Good luck Rich
/ Power Trac Update #26
Thanks Rich for the great information!
What part of the US do you live in?
Kevin
/ Power Trac Update
Kevin:
I live in Willington, Connecticut. If you are within driving distance you can check out my tractor.
Rich
/ Power Trac Update #28
Carpenter,
Have to gotten your PowerTrac yet and how do you like it? Any problems? What attachment do you have?
kevin
/ Power Trac Update #29
Well guys, I just about had my mind made up about which Power Trac I was going to purchase but then they just came out with a 2422 model. This is the same size as the 400 series tractors but with the capabillity of having a backhoe attachment. I am definitely going to have to take a ride to the factory to see if this model will suit my needs or be just a little too much machine for my purposes. They don't have much information available on this model yet, but I will keep you posted when I learn more information.
Still undeceided,
TractorGolf
/ Power Trac Update #30
TractorGolf,
I would like to know how things go when you go to the factory, my wife and I are interested as well!
/ Power Trac Update #31
Rich,
I my wife and I get out that way we will let you know. Please let me know if you get any new attachments!
Thanks again
Kevin
/ Power Trac Update #32
Kjc, I'm sorry for the late reply, but life gets complicated at times.
I,ve had my PT425 for about two months. I live in Oregon, so shipping was a rather expensive $1,500; that was for the tractor and two pallets of implements. If you have a choice don't use Overnite Freight; they took forever and the tractor had lots of paint missing when it arrived.
I purchased a 60" finish mower, cement mixer, post hole auger, small and large buckets, rake, forks, boxscraper and snow blade. I've used the mower a lot and it works well; it's nice having it mounted on the front. The cement mixer is also handy; you can mix and then dump it right in the hole. I haven't used the rest enough to really give an honest opinion.
The tractor has worked well after one initial problem. When it arrived, the throttle wasn't working properly. The low end throttle stop on the engine is too flimsy, so when you throttle down the adjustment screw goes past and gets stuck. Once I realised this I was careful not to push too far forward on the lever; but it's something Kohler should take care of. Other than that, the tractor has run great. I love the auto attachment feature; easy to do and easy on my back. As WP has already said, driving an articulated rig takes some getting used to.
Like everything in life, the Power Trac has it's pros and cons. The front mounted attachments are great for mowing, plowing snow, post hole auger, etc. but not so good for rakes and boxscrapers. The hydro drive is nice but you can get in trouble if you're operating at high rpm; it moves Fast!! All in all I'm pretty happy with my purchase.
/ Power Trac Update #33
I know what you mean, dont worry about it!
Down the road please let me know how the post hole digger works, how the buckets work, rake, forks and the snow blade. These are all option I was looking at. I am not in any hurry!
Thanks again!
Kevin
/ Power Trac Update #34
To any and all PowerTrac owners. How is your attachments working! Please let me know, how and what type you have?
Kevin
/ Power Trac Update #35
I have the 60 inch deck, small bucket with teeth and the power angle snow blade. All work extremly well
and are over built like the tractor. My next two purchases will be the rotary cutter and the stump
grinder. I hope to purchase these this fall.
Good luck: PTRich
/ Power Trac Update #36
Thanks PTRich, I will be asking about them as well later on this year! Any problems with pushing wet snow?
KCook
/ Power Trac Update #37
We had a lot of wet snow this year, a lot more than I ever remember. When the snow was a foot deep or more and wet I had to turn into the snow a little when the plow was angled, this works very well with an articulating machine. I have a very long gravel driveway that is hilly with turns. I may put chains on it if we have another year like this one. The snow had to be very deep to stop it when the plow was straight.
Good Luck, PTRich
/ Power Trac Update #38
PTRich, do you have any problem moving dirt with the bucket or the blade? How about gravel?
KCook
/ Power Trac Update #39
Works great for moving dirt and gravel, I have the small bucket but it is deep so you can realy heep it on. It loads quickly and the hydralics are very fast and strong
Good Luck PTRich
/ Power Trac Update #40
Have been reading earlier threads and came on your thread regarding new pruchase of the PT425. Now that you have had it for some time can you give me an update on your recommendations regarding machine and attachments? I will also be shipping to the West (Montana) and any suggestions on how to do this without damage wil be appreciated. I would even consider picking up and driving back myself. Understand there is a tax issue that I think could be handled by a tax exempt form but not sure. Most of the attachements you purchased are the ones that I am looking at with exception of box blade and rake. I will not need the PT trailer but would pick up a double axle 18 footer and put some low sides on.
Paul
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A69167)
2014 INTERNATIONAL...
CAT 416F Front Loader Bucket (A68134)
CAT 416F Front...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
2018 MACK LR633 6X4 TA GARBAGE TRUCK (A66091)
2018 MACK LR633...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
