Power Trac PT425
Status
Not open for further replies.
/ Power Trac PT425 #421
Re: Power Trac Mowing Performance
Oh, and one more thing (sorry), how well does the loader dig? From the PT video, it appears that the front wheels lift up and spin when you apply down pressure on the loader to dig deeper. This stops forward progress. On the BX, the same happens but you still have the larger rear wheels pushing forward and they can be locked with the differential. On the surface, this would suggest to me that the BX would be a better “digger” than the PT (although, to be fair, I realize the PT has numerous advantages in other areas). Thoughts?
/ Power Trac PT425 #422
i better watch myself answering this one some of my former students from the ag. university where i was employed found me.
the first counter question is: which mower are you using rough or fine cut? 48 or sixty inches wide? what are you attempting to achieve?
1. lawn quality cut
2. just mowe
3. knock down the grass and start all over
1. lawn quality cut, depends on grass type, length, use of fert. and frequency of mowing.
if one wants this quality one should mowe at lest once a week to favor the under growth otherwise you kill all the new plants and the thickness and the look of your turf.
you cant' compare a belly mower (BX) cut with a free floating deck cut ... as far as quality grass mowing goes. Speed is of no essence in mowing. the height of the grass, the wetness of the grass, the density of the grass are what dictates the speed.
as posted by me before i can finish 10-11 acres in one our with my pt425 60 inch mower and two kunz acrease 57 inch trailing behind and charge 1 dollar per minute per mower and due an excellent job for my customer.
to your question of what to due because of your schedule. non rough mower spindles take a beating when you try to cut the long grass down to the expected height in one cut. this height in my area in spring is about 3.25 inches. the leftover of the grass when cutting long grass all at once, stunts the growth of the young, replacement grass and can cause a thatching problem.
if you have to cut long grass take it in increments of at least one inch at the time to restore your lawn to a nice even cut. also change direction by at least 15 degrees from the first direction of mowing.
we do horse pastures on estates even with larger mowers and we apply that same principle but with 5 inch intervals. for good density, broad leaf control and parasite control we only take contracts which allow us to mowe the pastures every 4-6 weeks during the spring and fall season.
the pt425 48 inch rough mower plus a kunz eng 5foot powered (14hps) eng. can knock down very tall grass at about 108 inches wide, (providing that you are not on a steep incline )at about 6 miles per hour without any problems.
remember most of these posted speeds by makers of mowers and tractors are to us in the mowing business hogwash. SORRY MOHAMMED i know i am cussing again.
straight line mowing has nothing to do with the tractor, mower. the operators experience is what counts. practice makes the master. fixing your eyes at a distant point and mowing toward is better then following a property or fence line.
good luck ... PLEASE stop comparing a lawn tractor with an articulated tractor .... not fair to either. kubota is great, we have several different types, very inexpensive to operate but they are not as versatile as a pt. i now have almost flipped all my kubota products trying to do what i can do with the pt425.
/ Power Trac PT425 #423
Bubenberg
Thanks for the reply. Perhaps I should have included a little more information. I have 3 acres of flat terrain to mow. One acre is “lawn” and 2 acres are “pasture.” For the lawn, I want a pretty decent cut but am not all that particular. For the pasture, I’m only looking for a cut sufficient to keep the neighbors from calling the Home Owners Association. I intend to get the 60” mower and can generally mow the lawn every week to 10 days. The pasture I would like to mow as infrequently as possible…say every 3 weeks. I am considering a Kunz or Swisher tow mower to speed the pasture cutting. However, at $1500-$1700, it’s hard for a home owner like me to justify. That said, time is money and I want to mow as quickly as possible.
I like everything about the PT except the lack of a diesel engine in the 18-25 hp range and the lack of a dealer network and ready resale market. I would choose the PT in a second if I were comfortable I could easily resell it if I wanted a different tractor. I keep considering the Kubota because I know I can resell that tractor now or ten years from now. But I like the PT best.
Anyway, thanks for all your input.
/ Power Trac PT425 #424
to mowe with the pt425 it should not take more than 1.5 hours including trimming and blowing. of the five acres with the 60 inch mower. early spring you may have to spend a little more time if you go to 10 day intervals. for that size lawn you really don't need a wing mower.
but i do know about those nice toys, oh i am sorry attachments to keep the home owners association happy.
resell value: yes that is true kubotas every where .. a friend of mine is a dealer and these used ones sit around on his lot a long time .. not your problem.
but the pt is something you buy and add on depending on your liking of toys/attachments, even i am guilty of, that i am supposed to earn a living with these machines.
if you take care of the engine (oil) and the hydrostatic system. the hoses you can replace at any hydraulic supply parts store. the kohler rep. in your area can do anything to keep you going. also pt will talk to your local lawn tractor dealer if there are any questions. i have seen people replace 3 engines 6000 hours in the prof. world with other tractors that did not have a great or no dealer net.
it is the sears, cadet and kubotas of this world that eventually stop supporting their older lines. we than have to go to the internet for these older discontinued models and year specific stupid little parts to keep these things on the lawn/road.
i have bought used/reconditioned parts from pt. also they have offered me to resell my 425 if i would upgrade to a 1845/1850. i do need the smaller machine due to my customers stupid little 48 inch gates to ten acre fenced in properties. i "sideways or lift my acrease over the top of the fence post of the gates. once this maneuver is accomplished off i go mowing at 14 feet each passing.
one more thing is you can use other mini skid attachments. i am in process of buying and adapting a loose matl. handler from ramroad ...love these finger extenders called grapplers ... i want them all ...look that site up.
call kunz and see if they know of something used
have a good sunday
/ Power Trac PT425 #426
Hans,
<font color=green> but i do know about those nice toys, oh i am sorry attachments to keep the home owners association happy. </font color=green>
You know that’s not a bad idea. If I actually get the Home Owners Association to complain, then maybe I will have the leverage I need to get the Wing mower purchase past the CFO (wife). /w3tcompact/icons/wink.gif
<font color=green> resell value: yes that is true kubotas every where .. a friend of mine is a dealer and these used ones sit around on his lot a long time .. not your problem. </font color=green>
Do you ever see any used PT’s for sale? I wrote an email to the factory and asked if they ever have used or demo PT’s available at a discount. They didn’t answer. I’m planning a factory visit the first of next week and will ask them in person.
<font color=green> i have seen people replace 3 engines 6000 hours in the prof. world with other tractors that did not have a great or no dealer net. </font color=green>
I am not that worried about getting support. I agree the PT's appear very easy to work on (at least the 400 series). I can get a new Kohler 25HP engine for about $1500 from Northern Tool. Main reason I would like a dealer network is for the resale market. Maybe Kubota should buy PT the same way Ingersoll-Rand bought Superstav. Different products for different, but related, markets. This way, PT could put Kubota diesel’s in all their products and Kubota dealers could sell and service the product. Would greatly expand the appeal. (I should get paid for these ideas). /w3tcompact/icons/smile.gif
<font color=green> i have bought used/reconditioned parts from pt. also they have offered me to resell my 425 if i would upgrade to a 1845/1850 </font color=green>
Since you need the smaller tractor to navigate the small gates, why don’t you convince PT to build a Cummins 18HP A900 Diesel prototype for you to "field test" for them? I think PT is underestimating the market for a 400 series diesel version. Professionals like yourself could often justify the cost. And there are plenty of home owners who buy tractors as toys and wouldn’t mind paying the difference to have something to talk about with their friends.
By the way, I couldn’t find anything on Ramroad on Google. Do you have a link?
Thanks Hans.
/ Power Trac PT425 #427
/ Power Trac PT425 #428
pt has only once respondet to my e-mail .... but call them and ask for chris ( son in law of owner) dan or terry service rep. and you will get satisfaction, i have many times.
/ Power Trac PT425 #429
have spoken re: diesel engine, with chris at pt and have been told not right now. their is a good reason, that at first they build for anybody anything they wanted and found out that this takes way too much time and the re-generating cost could not be passed on to the individual customer. As an example there are some leftover items such as an atv type vehicle with two jet motors on the back to transport two patience "through the river and through the woods"...i want it now for a messily $15,000.00.
/ Power Trac PT425 #430
I just finished my first experience with "PT the Lawn Mower". I was very disappointed to say the least. Going across my hills was very unsettling. My front wheel ... uphill side ... lost contact with the ground numerous times while trying to cut across my hills. It was only the front wheel which lost contact with the ground. The rear stayed planted but ... I definitely didn't like the feeling. I even put my leg out to support the machine and myself at one point. Yeah right!!!!It seems like the oscillation worked against me in this situation. So i switched to mowing up and down the hills. "PT the Lawn Mower" didn't seem to like this any better. She wasn't going to tip over ... but she wasn't going up the hills either. At least not very well. The engine really struggled while running the mower and going uphill. I had major traction problems on my hills to boot. A couple of times i had to lift the deck up in order to make it up the hill. A couple of times i had to back down the hill to try a second time. I didn't stall at anytime. But i sure was close. I never had any problems like this with my simplicity garden tractor and i was totally unprepared for this. Now maybe we can attribute this to operator in experience. When i took out my lamp post with the canopy while trying to get as close as i could to the lamp post base thats what i attributed that to. But i'm not so sure about the other problems and i'm also not ruling out anything! It's late and i can't keep my eyes open. More on this later.
Status
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2020 Sellick S80 (A60462)
2020 Sellick S80...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2019 FORD F-250 CAB AND CHASSIS (A60736)
2019 FORD F-250...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
