POWER TAKEOFF
/ POWER TAKEOFF
I'D GUESS I HAVE TWO OPTIONS --- TRY TO BREAK THE PTO CLUTCH LOOSE OR SPLIT THE TRACTOR. IS IT POSSIBLE TO MAYBE BREAK THE PTO CLUTCH LOOSE BY DEVISING A "FORCE BAR" TO THE PTO SHAFT AND WORKING IT BACK AND FORTH ?? HOW FRAGILE ARE THE GEARS --- WOULDN'T WANT TO DO MORE DAMAGE THAN GOOD ??
BAR BILL
/ POWER TAKEOFF #22
starting under a pto load with clutch pressed should handle the force bar issue. IE. the shock load of starting is likely better than you can do with a bar with respect to not breaking something.
IE.. I pop stuck bolts loose without breaking them with an impact gun.. if I use a breaker bar I generally twist stuff off.. etc. it's that shock load.. etc.. that helps out..
/ POWER TAKEOFF
GENTLEMEN,
THANKS FOR ALL THE INFO !! THERE IS A WORLD OF KNOWLEGE OUT THERE.
I FINALLY SOLVED MY "STUCK PTO CLUTCH" PROBLEM.
I WAS ADVISED TO TAKE IT TO OUR LOCAL JUNIOR COLLEGE THAT HAS A FARM IMPLEMENT CLASS. PRETTY IMPRESSIVE I MIGHT ADD. THEY PUT THE OL' FORD PTO ON A "DYNO" --- LOADED IT DOWN AND BROKE THE CLUTCH LOOSE. IT WAS A "NO CHARGE" BUT I DONATED $100 TO THERE SHOP. REALLY CHEAP CONSIDERING WHAT IT MAY HAVE COST ME FOR A MECHANIC.
THANKS AGAIN --- YOU MAY BE HEARING FROM ME TIME TO TIME.
BAR BILL IN IOWA
/ POWER TAKEOFF #24
gld to hear you got it unstuck.
yep.. a variable dyno is a good safe way to apply a load to a pto if you suspect a stuck pto clutch..
soundguy
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
Caterpillar D7G Dozer Parts and Service Manuals (A63117)
Caterpillar D7G...
2011 Hyundai Santa Fe SUV (A61574)
2011 Hyundai Santa...
Claas Lexion 450/460/465 Combine Service and Parts Manuals (A63117)
Claas Lexion...
UNUSED WOLVERINE HYD MINI AUGER (A64281)
UNUSED WOLVERINE...
(2) UNUSED 15-19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15-19.5...
