Power steering
/ Power steering #1
budepps3760
Montgomery, Al
Mahindra 2810
I have an unusual situation that I would appreciate input on. Yesterday on my Mahindra 2810 I was having difficulties with my power steering. If I rotated the steering wheel to the left I had power steering but if I rotated the steering wheel to the right I had no power steering. Any ideas as to the possible cause?
/ Power steering #2
What type of power steering do you have? If you have assisted steering it might be so easy as a adjustment of the servo valve.
/ Power steering
It is assisted power steering. Have not had any issue and then all of a sudden it popped up.
/ Power steering #4
Probably control valve not directing fluid to other side.
/ Power steering
Took to repair shop. Determined to be damaged front rod. I remember what caused the damage. Using heavy land the front came up of the ground and I guess when it came down the downward pressure damaged it. Getting replaced now. Now I need to look at front end weights for tractor
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A64556)
2015 Hyundai...
Meteer 6R Corn Head Reel (A66408)
Meteer 6R Corn...
2004 TOYOTA7F GU26 FORK LIFT (A59914)
2004 TOYOTA7F GU26...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
2022 EZ-GO ELITE...
