Power steering with Vaseline?
/ Power steering with Vaseline? #1
stan33
Hi,
I'm rebuilding my power steering cylinders (MF 135 cylinders on an MF 240) and a mechanic told me that I should apply Vaseline to the internals.
Is this advisable or is it just a rural myth grown credible through the re-telling. Also can I use lithium grease instead?
/ Power steering with Vaseline? #2
I was a Bobcat mechanic for a while and we used vaseline on the o rings. worked well and does not eat the o rings. Try it it works. Lithium grease might work but it might eat the o rings and will cost more so why? Ed
/ Power steering with Vaseline? #3
Because he really doesn't want to check out with an industrial size tub of Vaseline :)
When you live in a small town with one drug store and you go in and the only thing you ask for is Vaseline, I guarantee you will do as I did and tell the sales girl "it's for my tractor".
And guess what, they had run out of it.
/ Power steering with Vaseline? #5
The beauty of using petroleum jelly for the assembly of hydraulic systems is that it is 100% petroleum and compatible with all common petroleum based fluids used in transmission, gear boxes or hydraulic systems. Because it is 100% petroleum, Vaseline dissolves away completely, unlike greases that leave their soap stocks or lithium bases undissolved and available to "gum up the works".
/ Power steering with Vaseline? #6
and its great for holding loose bearings/ parts in place for assembly ....
Informational Lot - Shipping (A63689)
Informational Lot...
2022 Bobcat T770 (A64126)
2022 Bobcat T770...
Wheel Loader Forks (A64126)
Wheel Loader Forks...
2017 Kia Rio Sedan (A61574)
2017 Kia Rio Sedan...
3 Brake Drums (A62613)
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
