power steering problem JD-415
/ power steering problem JD-415 #1
leftybob
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I purchased a 425 with les than 300 hrs. and the steering is stiff not at all like my 345. I changed the oil and filter but didn't help at all. What is the next step?
/ power steering problem JD-415 #2
does the deck lift properly? Should be the same hydraulic circuit.
Lift works fine. I also checked the greaseable axle shafts
/ power steering problem JD-415 #4
Try lifting the front tires off the ground, easy if you have a FEL. It should turn very easily, if not something must be binding.
/ power steering problem JD-415 #5
Do the tires turn evenly as you turn the steering wheel or does the steering wheel turn and the tires don稚?
I don稚 recall if the 425 has tilt steering wheel or not. If yes does the stiffness change when changing the tilt angle of the steering wheel?
2018 Nissan Frontier Ext. Cab Pickup Truck (A66736)
2018 Nissan...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
2018 CASE 750M WT CRAWLER DOZER (A65056)
2018 CASE 750M WT...
