power steering problem JD-415
/ power steering problem JD-415 #1
leftybob
Bronze Member
Barnhart, Missouri
Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
I purchased a 425 with les than 300 hrs. and the steering is stiff not at all like my 345. I changed the oil and filter but didn't help at all. What is the next step?
/ power steering problem JD-415 #2
does the deck lift properly? Should be the same hydraulic circuit.
Lift works fine. I also checked the greaseable axle shafts
/ power steering problem JD-415 #4
Try lifting the front tires off the ground, easy if you have a FEL. It should turn very easily, if not something must be binding.
/ power steering problem JD-415 #5
Do the tires turn evenly as you turn the steering wheel or does the steering wheel turn and the tires don稚?
I don稚 recall if the 425 has tilt steering wheel or not. If yes does the stiffness change when changing the tilt angle of the steering wheel?
2003 International 7400 T/A Dump Truck (A66736)
2003 International...
1984 ROLL OFF TRAILER (A67714)
1984 ROLL OFF...
Unused 2022 WIFO WBGS Hydraulic Bale Grabber Skid Steer Attachment (A66734)
Unused 2022 WIFO...
213130 (A64276)
213130 (A64276)
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
