Power steering not working
/ Power steering not working #1
David Wayne
Central Ohio
Kubota L3400
I posted this under construction, no replies so i will try here.
I have a ford 4500 TLB that I have been fixing up for the last couple of months. I have pretty much rebuilt the front end to reduce steering slop. Now the power steering doesnt work.
I dont suspect the pump as it worked before, oil level is OK. It shares the oil resivore with the backhoe. Pins & bushings are not too tight, I can turn it by pulling on the tire while it is jacked up. I did go the cheap route when replacing the hyd. fluid & bought 303 that is on sale at TSC & it is a bit thicker oil?? And I dont know what the little linkage is on the PS cyl that controls a valve, or how to adjust it. Any help will be much appreciated.
Photos will be along later I am not good on the computer, thats what I had kid for. And sorry for the spelling, cant find spell check. Got to go to work now. Thanks again.
Today I adjusted the linkage on the cyl. with the wheels off the ground. I cant go either way without the wheels turning so I guess its set right. Also tells me the pump is working, 1st adjustment was with the tractor not running,turnned it way too far. when I started her up she was turning quick & I couldnt stop the steering wheel,had to shut it down.
/ Power steering not working #2
i veey much doubt it was a lube issue.. probably could put atf int here and it would work.. though not the ideal fluid.
start checking for flow and pressure..
post back.
soudnguy
Got busy working on other things, now i am back to the tractor. I decided to take it all apart again since the PS cyl leaked some. With the parts on the bench I was figuring out how this works & I think I screwed up. While re-rounding holes & adding bushings to take out slop,I took out the play needed for the rod to operate the valve on the cyl. So all I need to do is remove my bushing. I will know in a few days for sure when I put it back together.
I will post how it went (with pics.) when I get done
/ Power steering not working #4
keep us posted. yep.. if VIC type. it has to move some to actuate the hyds.. etc.
soudnguy
/ Power steering not working #5
soundguy
Some pics as I promised, The 1st is from the add when I bought it. Then some of the screw up I had to re-do. And one of current with a lot still to do.
2021 Ford Explorer SUV (A61574)
2021 Ford Explorer...
2018 Volvo VNL Truck, VIN # 4V4NC9EH6JN894692 (A61573)
2018 Volvo VNL...
2010 HINO 268 4X2 S/A NON CDL 26FT BOX TRUCK (A59912)
2010 HINO 268 4X2...
2021 JOHN DEERE 331G SKID STEER (A62129)
2021 JOHN DEERE...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
