Power steering lines ford 445
/ Power steering lines ford 445 #1
Markhodges78
Ford 445
I am the new owner of a ford 445 backhoe when I bought it the steering didn稚 work after filling with fluid I found that the line down by the crank shaft has holes in it I have removed the lines and found that the hole in right at the bend so I am going to have to replace the line but I can not find the lines anywhere does anyone have any clue where I might locate these lines are maybe part numbers for them
Thanks in advance
Mark
/ Power steering lines ford 445 #2
Mark, they made a plain 445, 445A, 445C, and a 445D, which one do you have and we can help you more
If you're not sure, post us the info on the tag under the hood, or off the flat boss above and to the rear of the starter (stamped in, not cast )
445 & 445A steering lines - New Holland (445) - 3 CYL UTILITY TRACTOR (1/78-5/85) Parts Diagrams
if you have the "C" or "D" we need to know 2 or 4 wheel drive and if 4WD axle info too
I have the 445
/ Power steering lines ford 445 #4
see your needed line in the drawing? sadly most if not all the lines will have to come from NH
Yes I believe it’s the 12 & 13
Thanks so much
Ok next? Not sure what this means I know we have OD and length but not sure on the x240
HYD TUBE,9.53 mm OD x 240, 172.5 mm L
12 HYD TUBE,9.53 mm OD x 285, 191.5 mm L
13 HYD TUBE,9.53 mm OD x 203.5, 136.5 mm L
13 HYD TUBE,9.53 mm OD x 360, 136.5 mm L
/ Power steering lines ford 445 #8
Thanks in advance
Mark
Check with New Holland/Ford, they have a parts manual but you have to do some looking to find it, they dont make it easy. Look for the tab search by model.
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2022 EZ-GO ELITE...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
