Power steering lines ford 445
/ Power steering lines ford 445 #1
Markhodges78
Member
Ford 445
I am the new owner of a ford 445 backhoe when I bought it the steering didn稚 work after filling with fluid I found that the line down by the crank shaft has holes in it I have removed the lines and found that the hole in right at the bend so I am going to have to replace the line but I can not find the lines anywhere does anyone have any clue where I might locate these lines are maybe part numbers for them
Thanks in advance
Mark
/ Power steering lines ford 445 #2
Mark, they made a plain 445, 445A, 445C, and a 445D, which one do you have and we can help you more
If you're not sure, post us the info on the tag under the hood, or off the flat boss above and to the rear of the starter (stamped in, not cast )
445 & 445A steering lines - New Holland (445) - 3 CYL UTILITY TRACTOR (1/78-5/85) Parts Diagrams
if you have the "C" or "D" we need to know 2 or 4 wheel drive and if 4WD axle info too
I have the 445
/ Power steering lines ford 445 #4
see your needed line in the drawing? sadly most if not all the lines will have to come from NH
Yes I believe it’s the 12 & 13
Thanks so much
Ok next? Not sure what this means I know we have OD and length but not sure on the x240
HYD TUBE,9.53 mm OD x 240, 172.5 mm L
12 HYD TUBE,9.53 mm OD x 285, 191.5 mm L
13 HYD TUBE,9.53 mm OD x 203.5, 136.5 mm L
13 HYD TUBE,9.53 mm OD x 360, 136.5 mm L
/ Power steering lines ford 445 #8
Thanks in advance
Mark
Check with New Holland/Ford, they have a parts manual but you have to do some looking to find it, they dont make it easy. Look for the tab search by model.
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A61568)
2012 Ford F-350...
Unverferth 275 (A64126)
Unverferth 275...
445 (A63290)
445 (A63290)
