Power Steering for L245DT
   / Power Steering for L245DT #31
KUBOTA L245DT
Does anyone have any information on extending the splined shaft on the front of the motor? I would like to extend the shaft and mount a pump on the metal bracket in front of the shaft. The shaft measures 1.0 inches in Diameter. I need to extend about 10 inches. All information is greatly appreciated!
Kenan
Kenan, You moght check with a dealer or even ebay. Their is a coupling that connects the crank to the pump, it fits on the splined shaft and has a flexable extension.
Bill
   / Power Steering for L245DT #33
Have the same tractor. My hydraulics run from the pump on the side of engine to the 3PH. On the 3ph, there is a small manifold block that feeds the FEL control valve. Question: Could I install a tee fitting to the FEL Valve supply line coming from this manifold and plumb the priority valve from there?
2015 SKY TRAK 6036 TELEHANDLER (A58018)
2015 SKY TRAK 6036...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
