Power Steering for L245DT
   / Power Steering for L245DT #31
KUBOTA L245DT
Does anyone have any information on extending the splined shaft on the front of the motor? I would like to extend the shaft and mount a pump on the metal bracket in front of the shaft. The shaft measures 1.0 inches in Diameter. I need to extend about 10 inches. All information is greatly appreciated!
Kenan
Kenan, You moght check with a dealer or even ebay. Their is a coupling that connects the crank to the pump, it fits on the splined shaft and has a flexable extension.
Bill
   / Power Steering for L245DT #33
Have the same tractor. My hydraulics run from the pump on the side of engine to the 3PH. On the 3ph, there is a small manifold block that feeds the FEL control valve. Question: Could I install a tee fitting to the FEL Valve supply line coming from this manifold and plumb the priority valve from there?
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
SKID STEER ATTACHMENT HAMMER (A58216)
SKID STEER...
2016 Komatsu WA380-8 Articulating Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel (A59076)
2016 Komatsu...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
