Power Steering for L245DT
   / Power Steering for L245DT #31
KUBOTA L245DT
Does anyone have any information on extending the splined shaft on the front of the motor? I would like to extend the shaft and mount a pump on the metal bracket in front of the shaft. The shaft measures 1.0 inches in Diameter. I need to extend about 10 inches. All information is greatly appreciated!
Kenan
Kenan, You moght check with a dealer or even ebay. Their is a coupling that connects the crank to the pump, it fits on the splined shaft and has a flexable extension.
Bill
   / Power Steering for L245DT #33
Have the same tractor. My hydraulics run from the pump on the side of engine to the 3PH. On the 3ph, there is a small manifold block that feeds the FEL control valve. Question: Could I install a tee fitting to the FEL Valve supply line coming from this manifold and plumb the priority valve from there?
More info coming soon! (A56859)
More info coming...
2336 (A58376)
2336 (A58376)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2002 CATERPILLAR D6M HIGH TRACK CRAWLER DOZER (A52709)
2002 CATERPILLAR...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2001 TRIPLE E TRI-AXLE STEPDECK TRAILER (A58214)
2001 TRIPLE E...
