Power Steering Fluid - JD770
/ Power Steering Fluid - JD770 #1
JeffSpencer
North Carolina
4200 HST
Hey guys,
I'm trying to help a friend of mine, who is the new owner of a used JD770. He says the power steering is a bit jerky and is trying to find out where to add power steering fluid. He lives about 4 hours away from me, so I can't look at the tractor. My initial thoughts are, it's all hydraulic.. one fill point.
I have a 1999 4200, his is a 1995 790.
Anyone know if this is a separate system,.. or all hydraulic? Where does he add power steering fluid?
Thanks -Jeff
/ Power Steering Fluid - JD770 #3
On the 770 it's a common oil sump. Two pumps one for the steering ,one for everything else. The dipstick is on the back of the tractor by the 3 point top link,fill is above it . The power steering option also added a spin-on filter in front of the left rear tire. Thier is also a strainer in the back axle.I know with mine ,if I don't run the John Deere Hy Guard Low-vis oil it whines from the pumps.
/ Power Steering Fluid - JD770 #4
Since your friend is a new owner of the JD 77o, I suggest he change hydraulic fluid, filter and clean the sump screen. Good to start fresh on an unknown machine.
215603 (A63276)
215603 (A63276)
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
(4) Drive Tires off Kinze 3000 Planter (A65640)
(4) Drive Tires...
2016 FORD TRANSIT T350 EL SRW HI ROOF VAN (A59914)
2016 FORD TRANSIT...
2012 Hyundai Sonata (A62679)
2012 Hyundai...
