Power steering cylinder...
/ Power steering cylinder... #21
I was going off what Chris said.
Like I said. If you owned one of these yourself, you'd better understand what's going on here. When I owned those Jinmas, the one with the front cylinder was tapped so the fittings would face either up or down. Mine were up. Chris concurred that his were up as well. However the photos posted by the OP clearly show that his cylinder is tapped so the fittings can face either front or rear. The suggestion is for him to rotate the cylinder so those holes face forward, then select the desired fittings to route the hoses up and over. Regardless of which type cylinder, either can be rotated on its bracket. Following that, the only difference is which fittings to select for routing the hoses up and over.
//greg//
Got caught up with a couple other things this weekend. Will post more about the change over mid part of next week..
Gehl Mix-All Grinder Mixer (A66408)
Gehl Mix-All...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2003 Chevrolet C7500 Flatbed Truck (A62613)
2003 Chevrolet...
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
FIXED FIFTH WHEEL ATTACHMENT (A65643)
FIXED FIFTH WHEEL...
