power shuttle ?
/ power shuttle ? #21
IMHO the biggest advantage of a power shuttle is a wet clutch versus a dry clutch on a mechanical shift transmission. Should last longer. That is offset by the added electronics and complexity of the power shuttle. When I hit the lottery my last tractor will be a cabbed unit with power shuttle or power shift.
/ power shuttle ?
H.S.T. trans has always been the best option but I was looking for a loader that had around 2000 lbs. cap. I also wan't the least electronics possible cause my tractor sits outside under tarp and I do work my self.That puts me in the early 2000 area. I like tc45d,4720, and jd 110.Budget is around 20 for a cab less model.:confused3:
/ power shuttle ? #23
No electronics in my 2007 or 2016, no DEF either.
/ power shuttle ? #24
Older hip joints or knees are a couple I can think of.
I have Knee/ankle/foot and one hip that all give me problems. What I find is the clutch doesn't bother me but a single pedal on a HST will just about cripple me in a couple hours. A dual pedal HST is better but even that isn't nearly as good for me as a shuttle.
/ power shuttle ?
Paul do u have a loader on your dk 40 ?Wich one ? Do u Like it, any problems. I like KIoti doesn't seem to have to much unnecessary electrical crap. Only problem I see is when I look for older ones they are far and few inbetween.:mad:
/ power shuttle ? #26
I have pretty bad knees and have an HST in the shop so they brought me a power shuttle. I prefer the HST as the pedals are side by side (Mahindra 2555) and I hardly use the brakes unless I am on a hill. The Power Shuttle I am moving my legs/feet a lot more. After being in the cab for 4+ hours I can feel it in my legs (especially the knees) because of the clutch/brake.
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2022 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2022 FREIGHTLINER...
2011 Freightliner B2 School Bus (A61568)
2011 Freightliner...
2013 FORD F-350 SUPER DUTY (A65643)
2013 FORD F-350...
2019 KENWORTH T370 FLATBED TRUCK (A65643)
2019 KENWORTH T370...
New/Unused 3 Point Receiver Hitch Attachment with Gooseneck Ball (A65583)
New/Unused 3 Point...
