power service addative
/ power service addative #41
1*PS has worked for me.
2*I sure do hate using that stuff each and every time I fill up! And the bottles always leak and that stuff is WAY NASTY! It has stained every vinyl or rubber type material in the back of my truck!
3*If I come across Howes - I'll give it a shot.
AKfish
1*Works for me too.
2*Know what you mean,measuring it out and pouring it through funnels adding it to 5 gallon cans got to be a messey PITA.
Solved that problem when i graduated from 5 gallon cans to a pump and drum set up.
Now I just dump a whole quart bottle in the 55 gallon drum when i go to fill it up.
Hooray no more funnels or measuring cups.
3*I just discovered Howes at the go mart truck stop 2 days ago so i may give it a try sometime.
Trouble is I have 5 quarts of power service on hand.
That is enough to treat enough fuel to last me for 5 years.
/ power service addative #42
Yesterday I used Howes to get my B3030 working right. I took the tractor from the barn and after 2 minutes the engine sputtered and stalled. I started it and the same thing occured. Looking at my fuel sediment bowl it appears the diesel fuel was gelling. Temperatures have been 10 to 30 F and last time I filled the tank was in October. Yesterday the temp was about 32 F.
I could not find any powerco at my local hardware store but found the Howes at a small EXXON minimart gas station. I paid $18.00 for it. I only needed a few ounces so I initially was reluctant to buy it ( only 1 size bottle for sale).
I added 5 ounces and after 1 minute of sputtering the engine started to work normally as good as new. No problem running the tractor after that. I am now a fan of Howes.
Here is a picture of my fuel sediment bowl before HOWES. Does it appear to have gelled fuel or water in it? Is the filter supposed to look gelatinous like this? When taking off the fuel sediment bowl what is the procedure and should I change the filter? The bowl did seem better after running the tractor.
/ power service addative #43
Nik, no reason to change the filter in the sediment bowl unless you experience more problems. The Howe's should straighten out the gelling problem and you will be good to go.
Sincerely, Dirt
/ power service addative #44
I use PS white bottle;3.2 oz per 5 gallon can. Minus(-24F) Friday, minus(-14F) Saturday and never got above +14F degrees while I was sno-blowing Sunday and not a hiccup;see no reason to look elsewhere??
/ power service addative #46
Howe's is good stuff. It's kept my 3510 starting / running in sub-zero temps this winter. I paid $8.99 for the big bottle like yours at the local Farm & Fleet.
The #@*% Mini-Marts really jab you on essentials. I know the local Mobil station gets $3.91 for a gallon of WW Fluid that costs $1.39 on sale at F & F (same brand and strength).
I suppose they gotta eat too. After all, there's no money in selling gas these days...
/ power service addative #47
There are known issues regarding biodiesel. The main problem with the product is the gelling point being higher than plain diesel. Other than this, some people are experiencing issues because the "blenders" are not properly mixing the biodiesel. Biodiesel is also known to have a shorter shelf life that plain diesel. The benefits of bio is that it does burn cleaner, and there are suggested environmental issues too. I don't want to get into the difference between cloud points and gelling, I'll leave that to the experts on the subject.
regarding PS, do some Due Diligence. PS web site states:
Directions:
Add Diesel Fuel Supplement +Cetane Boost as directed on the container label. Diesel Fuel Supplement should be added to the fuel at a temperature higher than the fuel cloud point. To ensure thorough mixing, add prior to filling tanks with diesel fuel. Store above 10ºF.
Most people (not all) keep their fuel additives and fuel near their tractors. If your tractor is stored in an unheated building, or you keep your bottle in your truck, think about what the temperature is of the bottle and your fuel before mixing.
According to their website, PS has the following Winter Performance Benefits:
Prevents fuel gelling in temperatures as low as -40ï½°F.
Equals the performance of a 50/50 blend of No. 2 and No. 1 diesel fuels
Lowers Cold-Filter Plugging Point (CFPP) as much as 36°F. keeps fuel-filters from plugging with wax
Boosts cetane up to 4 numbers for faster cold starts
Contains anti-icing additives protects against fuel-filter icing
I don't work for them, and I believe they will send me a check for a product endorsement as much as I believe in the tooth fairy.
Here is the link.
Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economy
/ power service addative #48
I live in Canada and if they make Howes here I have never seen it in any store here. I have seen it for sale at the local Citgo station "across the river" in Michigan.
The web site suggests the head office is in RI-Howes Lubricator: Contact
I live in the north and it's cold here-seems like it has been -25C all winter with lots of snow. I have used Power Service (white bottle in winter and silver bottle in summer) for years and have never had a problem.
Late last year I bought #2 off-road diesel at that Citgo station in Michigan. It was -15C that day and the fuel poured out like a slushy into my container. I later added Power Service (white bottle) to the fuel as I poured it into my tractor. I never had so much as a one errant sputter from my always smooth running tractor engine. ;)
I am sold on the effectivesness of Power Service:)
/ power service addative #49
Northland Howe's is avaiable here in Canada some places anyway, I have picked it up a various truckstops across the province for use in my bg truck. Gary
/ power service addative #50
I had been buying Power Service at Walmart, but noticed recently that the large bottle, which is supposed to be 96 ounces, is now 80 ounces, for the same price. (Like what happens with the candy bars - the price stays the same but they get smaller). I then checked at NAPA, they still sell the 96 oz. bottle for about the same price as WM. Sometimes it pays to shop around.
/ power service addative #51
Here in SC Tractor Supply sells the PowerService for less than WalMart...and they still have the 300 gallon bottle where WalMart is the 250.
/ power service addative #53
I know some swear by the PS products. I swear AT IT. Using PS in the white bottle has left me on the side of the road a half dozen times. 2 years ago I switched to "Howes Diesel Treat" and have had no problems since.
Here's a comparison;
Howes is made in Canada where it gets COLD
PS is made in Texas where cold means wearing socks with your sandals
Howes is cheaper than PS white
Howes is Guaranteed to not leave you stranded (has some requirements to prove use)
PS is NOT guaranteed to do anything except drain your wallet
Howes has a pleasant odor
PS - not so much
Howes can reverse gel on a filter (not its prime function, but it does)
PS does not do a dern thang to reverse gel
Naturally, this is my opinion and YMMV
jb
I agree on Howes. Have not and will not use PS. Every gelling thread I have read has always had something like " I used PS, and gelled..."
We have used KLEEN-FLO and have NEVER had a gelling, freeze up issue.
http://www.ezoil.com/Products/Diesel_Aid.html also works great too.
JMHO.
/ power service addative #55
I hain't never sen a 250 or 300 gallon bottle of Power Service ?
I hope one of their stock guys will help me load that into the back of my truck!.. about 2100# I figure! for the 300G 'jug'.. ;)
soundguy
/ power service addative #56
Yep...dang near got another hernia putting it in the truck:D
Lol good come back:D:D:D.
soundguy
Must be for heavy duty service is why it weighs so much.;)
/ power service addative #57
The new bottles are all 80 instead of 96 ounces. I'm not sure if the 96 ounce bottles still out there contain their newer USLD formula or their old formula. TSC stores around here have had the 80 ounce bottles since last summer.
/ power service addative #58
My two cents worth: I mostly use PS in my Dodge because it is relatively cheap and readily available adding about every other tank. Never had a problem with it even while living up north. I have tried plenty of other additives and never noticed any earth shaking differences.
I hang onto the fuel injector cleaner containers that I buy for my gas powered vehicles. After I let them dry out, I set a bunch of them up and pour my diesel additive into them from a measuring cup and a funnel. It sure is easy to grab one of those bottles and dump it in the tank while at the pump rather than fumbling with a jug.
My fuel gauge quit working years ago in the Dodge so I top off around 400 miles on the odometer. I may be plus or minus on the amount that I add but not by much.
My tractor fuel is a different story. My useage can vary so sometimes the fuel sits awhile in my 100 gallon tank. For that application, I use fppf Total Power. fppf makes several different formulas but I never tried the others.
I had an older gent at a former tractor dealership that really knew my older Case very well. He was the one who recommended the fppf to me.
Howes is usually available at most truck stops. Truck stops tend to be pricey but if you happen to get in them regularly, they do have it on special quite often.
I hear plenty of people rave about Stanadyne additives even claiming better mileage. One of these days I need to pick some of that up.
PS makes that 911 version in the red bottle for emergency use. I never had to resort to that myself but I know others that have and they say it got them going again.
/ power service addative #59
Both are for ULSD unless the 96'ers are real old. My 96's are up to date. For clarification, in case anyone didn't figure it out, the 80 ouncers treat 250 gallons and 96 ouncers treat 300, hence my shorthand faux pas about 250 and 300 gallon bottles:eek:
/ power service addative #60
LB, this is what a 300 gallon bottle of Power Service looks like. I have parked my JD6410 near it as a size reference.
Ken
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
APPROX. 1000 GALLON FUEL TANK (A63291)
APPROX. 1000...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
