power port wiring
/ power port wiring #1
mitch G
John Deere L120
A rodent ate through the white and black wireds running into the Power Port of the L120. I discovered this after I had a problem starting. I have capped them off. still can not start. I wonder is the power port connection back wired through something that would ground the tractor or otherwise prohibit starting? Be warned I am not very mechanical.
/ power port wiring #2
not sure about that, but cant you just wire nut the cut wires back to where they should have been before mouse chewed thru it?, instead of just capping them off?
/ power port wiring
yeah that;s tomorrow's plan
/ power port wiring #4
The power port might be on the same fuse as something need to start the machine. Leave the wires capped and then check your fuses.
/ power port wiring #5
Have you looked for other chewed wires?
/ power port wiring #6
that my thought........ more chewed wires......
Caterpillar D4 Dozer Parts and Service Manuals (A63117)
Caterpillar D4...
King Kutter II Tiller for sale.
King Kutter II...
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A61572)
2015 JLG G12-55A...
2006 MINI Cooper Convertible Coupe (A61574)
2006 MINI Cooper...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
