Today, before draining the tank and inspecting the fuel line, I thought I would first install new air filters. I thought I had solve the problem because it worked really well up to about 2 1/2 - 3 hrs and then, the same old problem. This time I took a look at the clear fuel filter chamber and notice the fuel coming in, but not fast enough to keep it full. So I'm guessing the fuel tank or line is probably clogging. I did take a look at the fuel cap as suggested before I ran it today. It does not have a hole on top or if it does, it is covered with a factory flammable sticker. Anyhow, I took look at the inner rubber seal with the bulbous center and noticed debris coming out a hole in the center. So I popped the seal out and found the foam inside was coming apart. I replaced it with a new piece of foam, cleaned up the seal and cap and reinstalled it. After I returned home once the tractor started to lose power, I noticed a small leak around the fuel cap. Could this be a source of my problem? The tank was less than 1/2 full and I know I did not spill anything in that area. I have not tried the cap removal technique as suggested because I just got that message when I returned today. Might it be as simple as a new gas cap?
