Power comparison
/ Power comparison #1
docfoc
Woolage Green
Kubota B7100
I have a Kubota B7001D and have been thinking about getting a bigger compact such as the L1802DT... does anyone know if this is a significant increase in power , I am mainly using it to tow a 3T muck trailer and the B7001D struggles a bit , but not sure if the L1802DT would also be under powered... Any thoughts?:confused:
/ Power comparison #2
Don't know the h.p. of the two units but when towing weight is your friend.
/ Power comparison #3
/ Power comparison #4
Those are both pretty small tractors for the weight you are towing. I think the L model you mentioned is slightly larger and would have had about 10 percent more power when new. However, since those are both tractors from the 1980's or earlier, one or both of them may be a bit old and tired by now. If it's yours that is showing its age and the other one is in better shape, it might make the replacement worth considering.
/ Power comparison
Thanks .. good points.. I may be just asking too much from it ...
KMC 12 Row Rip Strip Till (A64126)
KMC 12 Row Rip...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
New 2200lb All Steel Adjustable Gantry Crane (A62679)
New 2200lb All...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
